Tryall Hole Rear Rim ?
trialsrider.chris
hi everyone
wanting to know . 1. are the rear tryall hole rims strong enough to take hits on stuff. do they buckle or dent easy??
2. the spoke holes are offset from the centre ... if used on a onza limey 320 would the disk caliper touch the spokes ??
help appriciated
thanks
chris
Edited by trialsrider.chris
That depends on your hub a lot. You can lace them all heads-out on the disc side as a pre-caution in any case.
EDIT: Just realised your title's "hole rear hub" - assuming you mean the H hub, then yeah, heads-out disc side would be the way to go.
What will it be like with a Onza Sealed Disk Hub ?
Thanks
Sam :D
Edited by Cahill Trials Kid
