Back Brake Pads?
trials jack
snap! im pretty sure im using rockman blues (they are blue and came with a recent fourplay from tarty) and im using them with the white trialtech rims ungrinded
only a few days ago i considered a grind, and after looking at tartys site and the pad reviews here...i think thats what the pads seemed to be designed for?! im not sure if thats what rockman had in mind when coming up with them or its tartys experience and recommendation
copied from tarty:
"Top secret compound offers the best performance in both dry and wet conditions (as long as they are used with a grind)!
Recommended Use
Blue: Sharp light grind for dry weather, sharp slightly deeper grind for wet weather
Green: Smooth rim.
really hope there is quite a difference though...only yesterday when trying for the first time to lock the wheel with two fingers (using one finger all the time is normal- right?) did i realise quite how much the brake was slipping! (as a result the hub was engaging..crank was turning, and made 'rocking' inparticular a nightmare - im looking forward to another leap in confidence!)
Edited by chris4stars
just lookin on the members side off the forum, and theres a similar post, if you dont want grind then check www.heatsink.com appparently there top rider's use these pads with non-ground or non tar'd rims! im getting some hopefully so i'll keep you posted if you dont get any?
sorry its www.heatsinkbikes.com
use a little tar but dont grind keep ur rim smooth tht shud make it better.
ah...you should perhaps tell tartybikes, and every other person whos written a pad review for the roackman blues who ALL say it is better with a grind...
(the guys reviewing are only experienced and probably the most knowledgable up and down the country - what do they know :S)
for what was a sensible topic and question...they are some shocking replies guys
