Brake Mount Spacing?
eskimo
I'm looking to see if anyone has any input on spacing the mounts for Vee-brakes. I've had a play but can only do so much with putting pads, arms, boosters on the floor and measuring.
I came to the conclusion 100mm seems sensible (funnily enough a common size). But i'm still not convinced. So any input is welcome.
The rim i'm basing this is 33mm from the outside. But there may come a time when i need clearance for 38mm.
And obviously we have pad spacers and pad wear to allow adjustment somewhat. Oh and i can't go bigger than 100mm, but that isn't an issue with the current rims sizes.
Thanks!
I'd have about 96-97mm, the widest you can possibly have and still allow for an XTR booster :P.
I run Heatsink adaptors so I can adjust the position in set amounts, but I really struggle to run new pads and an XTR booster with my rim (47mm). The lowest spacing I can use without removing the booster is about 94mm, and thats just not enough with 14mm thick pads. If you are using a wide rim, I'd say it needs to be about 100 or even 105mm to accomodate most new pads (which tend to be 15mm or more).
same as me , but running a dx32 38 mm rim all good :)
