Vortexor Posted January 13, 2010 Report Share Posted January 13, 2010 (edited) Need some advice please I Have a Onza Blade and got the built in tensioners that go through frame and im going to get a Zoo Lynx short 4/bolt off tarty now i can't set the tensioners up on the Lynx totally different so what will i need to buy and i will be buying a full wheel build if i need a new hub. i know it runs with snail cams so i have to buy a new wheel with a hub thats made for snail cams to use on or can they work on the onza hub? or is it all different, also the chain sprocket on back of onza Hub will that screw off the onza and on the Echo TR wheel build on Tarty at (£99). Cheers for posting Edited January 13, 2010 by AndyyRider Quote Link to comment Share on other sites More sharing options...
Vortexor Posted January 14, 2010 Author Report Share Posted January 14, 2010 BUMP Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 14, 2010 Report Share Posted January 14, 2010 You should just be able to use snail cams with your old wheel and new frame... Also, the TR wheel will take the sprocket; however..it's nigh on impossible getting those sproclets off if it's been ridden hard. Quote Link to comment Share on other sites More sharing options...
BringThatShtIn Posted January 14, 2010 Report Share Posted January 14, 2010 Also, the TR wheel will take the sprocket; however..it's nigh on impossible getting those sproclets off if it's been ridden hard. Screwdriver between the spokes, hammer end of screwdriver so it pushes against the sprocket, work your way round, eventually you can lever it off =) Quote Link to comment Share on other sites More sharing options...
Vortexor Posted January 15, 2010 Author Report Share Posted January 15, 2010 Cheers Guys Quote Link to comment Share on other sites More sharing options...
