Mtchell Posted January 9, 2010 Report Share Posted January 9, 2010 (edited) Hi has anyone one got or used the goodridge hosing, I,ve just order a front kit for my disc as i completey fooked up the shortening of the hose. It cost my £26 which I thought was ok as it comes with the olivers and bits and bats. Now I was wondering would it be worth investing in a rear kit for £40 for my magura?, bearing in mind I already use a braided hose for my rear brake? any advice would be great cheers Edited January 9, 2010 by Mtchell Quote Link to comment Share on other sites More sharing options...
crispyboy Posted January 9, 2010 Report Share Posted January 9, 2010 Its just a carbon look not real carbon Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 9, 2010 Author Report Share Posted January 9, 2010 Its just a carbon look not real carbon yer i know that , they're shouting out its 20% more powerful is it true or sale blab Quote Link to comment Share on other sites More sharing options...
chris4stars Posted January 9, 2010 Report Share Posted January 9, 2010 noticed that the reviews for this stuff is great, but the pictures i could find just looked like regular braided hose?! any chance you could post a close up pic when you get a chance? Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 9, 2010 Author Report Share Posted January 9, 2010 noticed that the reviews for this stuff is great, but the pictures i could find just looked like regular braided hose?! any chance you could post a close up pic when you get a chance? Yer i will do mate and get few of the end of the hosing for you too Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted January 9, 2010 Report Share Posted January 9, 2010 I got it, it's really good. My brakes are bled with water, no anti freeze or anything, and even in my garage where it gets below freezing pretty often, brake doesn't freeze. My mate had the regular hosing and his freeze all the time. Also a lot less chance of popped crossovers and that. I'd recommend it any day Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 10, 2010 Report Share Posted January 10, 2010 its pretty indestructable, but bear in mind that its designed for dot fluid which is a lot thinner than magura mineral oil, so it will make your brakes slower to react, its not such a problem with water though, but its still a bit slower than standard hosing. Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 10, 2010 Report Share Posted January 10, 2010 its pretty indestructable, but bear in mind that its designed for dot fluid which is a lot thinner than magura mineral oil, so it will make your brakes slower to react, its not such a problem with water though, but its still a bit slower than standard hosing. This is true, mine has generally felt like an oild bleed when bled with water, lol. Maybe a little bit thinner. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 10, 2010 Author Report Share Posted January 10, 2010 Oh right sounds quite positive,I run a water bleed at the moment on the rear so it,ll be slower to return with goodridge yer? Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 10, 2010 Report Share Posted January 10, 2010 Yes, a bit, but it's not really bad. It's still pretty quick acting. Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted January 10, 2010 Report Share Posted January 10, 2010 Yeah, mine's bled with water. If you do a decent bleed, it still feels a lot better than oil Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 10, 2010 Author Report Share Posted January 10, 2010 Oh cool sounds right enough then while we're on brake is it worth investing in a carbon lever aswell my mate says they don't flex when the brake reaches it biting point? Quote Link to comment Share on other sites More sharing options...
darrenhopper Posted January 14, 2010 Report Share Posted January 14, 2010 Well Carbon lever blades don't bend...... They do shatter though. As for goodridge lines, I reckon they're always worth the money. Though if you've already got braided lines then I don't see how you'll notice any improvement, aside from them being prettier. Quote Link to comment Share on other sites More sharing options...
