Tartybikes
gu trials
was just curious about the four bolt mount tapping from tarty, at the bottom it says only on frames with the mounts ontop of the seat stays, does this mean that they dont do forks ? where as if you click the drop down menu to pick which one you want the forks are mentioned aswell as a frame.
it just confused me a little bit
Haven't seen any but seems like it may be referring to mounts on the underside of the seat stays-where it might be more difficult to get a thread tapper in and ensure the threads are straight, by the look of things they do forks on the front and back mounted types but reading about the way the do it by threading out larger threads and putting an insert in to which you then screw you normal mount screws into, it may not work properly with the thin braze on mounts that you normally get with the magura mounts (which are quite thin all over and don't seem to have much to insert a threaded insert into) but probably only works on the mounts that have the little solid block of a mount, but I can't be certain why not give them a quick phone they always seem happy enough to help!
Edited by japslap
