ruairidh m Posted January 7, 2010 Report Share Posted January 7, 2010 Do you have to switch to double disc in the winter because my rim brakes are useless in the cold. Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted January 7, 2010 Report Share Posted January 7, 2010 Do you have to switch to double disc in the winter because my rim brakes are useless in the cold. No you just don't use your bike. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted January 7, 2010 Report Share Posted January 7, 2010 Do you have to switch to double disc in the winter because my rim brakes are useless in the cold. Good grind, good pads and a water with anti freeze blead (if you run maggy) But DD *** Quote Link to comment Share on other sites More sharing options...
Adam Griffiths Posted January 7, 2010 Report Share Posted January 7, 2010 water and antifreeze bled brakes freeze up after a short time riding in the winter may aswell keep oil bled for winter and the water for summer Quote Link to comment Share on other sites More sharing options...
Little Yoshi Posted January 8, 2010 Report Share Posted January 8, 2010 Where about you from lad? Quote Link to comment Share on other sites More sharing options...
mwiggi Posted January 8, 2010 Report Share Posted January 8, 2010 water and antifreeze bled brakes freeze up after a short time riding in the winter may aswell keep oil bled for winter and the water for summer I've been out riding for the last two day with a water bleed in my rear Magura and the first day the fluid inside froze up almost instantly after leaving the house. Today I used an anti freeze / water mixture and the brake functioned correctly all day. There was no change in stiffness compared with how the brake usually feel and the brake didn't freeze even though it did get buried several times. I mixed the concoction in my kitchen sink then undid all the grub screw in the lever and the bolt in the calliper. i had the calliper submerged in the mixture and the lever lower than the calliper with a bowl underneath. This causes a syphon effect to occur and leaves no need to suck the mixture through. I really enjoyed riding in the snow regardless of the constant loss of traction while trying to do gaps, as well as the lack of friction between the pads and the rims leading to useless brakes caused by the deep snow I insisted on riding through at every opportunity. Its been one of the best birthdays I have ever had! Bring on the snow next year. Quote Link to comment Share on other sites More sharing options...
Mtchell Posted January 9, 2010 Report Share Posted January 9, 2010 Like ardmair said just don't use your bike mate and wait it out, it is annoying, yes but its all so annoying slipping every minute of riding Quote Link to comment Share on other sites More sharing options...
Jake. Posted January 9, 2010 Report Share Posted January 9, 2010 I really enjoyed riding in the snow regardless of the constant loss of traction while trying to do gaps, as well as the lack of friction between the pads and the rims leading to useless brakes caused by the deep snow I insisted on riding through at every opportunity. How are you alive? Quote Link to comment Share on other sites More sharing options...
pogo Posted January 9, 2010 Report Share Posted January 9, 2010 Just ride where you can, crates defrost quite well, isn't there anywhere undercover you could ride, even to just get a quick ride in? Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted January 9, 2010 Report Share Posted January 9, 2010 put a summer tent thing up like i have so i can still bust some moves on 2-4 pallets in my garden , snow and ice clear really fun too Quote Link to comment Share on other sites More sharing options...
mista-neos Posted January 10, 2010 Report Share Posted January 10, 2010 put a summer tent thing up like i have so i can still bust some moves on 2-4 pallets in my garden , snow and ice clear really fun too Josh thats just dumb, go to the back of helfords and ride . Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted January 10, 2010 Report Share Posted January 10, 2010 but my halfrauds has no cover Quote Link to comment Share on other sites More sharing options...
mwiggi Posted January 12, 2010 Report Share Posted January 12, 2010 How are you alive? I ask myself that same question all the time. I nearly faceplanted doing one gap. Just lucky I guess. My tyres are as good as slick too! Quote Link to comment Share on other sites More sharing options...
Jordy P Posted January 12, 2010 Report Share Posted January 12, 2010 i use rim brakes, agreed useless in the wet and snow! haha i just use onza pads, tar with water/anti freeze mix. Been out the last couple of days though and theyre fine.... but if they do start playin up i jus get the rim hot by riding with brake on and it tends it pick up and start to lock better!!! Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted January 13, 2010 Report Share Posted January 13, 2010 lmao rims hot hahaaaa i use a built in radiator to heat my rims lol Quote Link to comment Share on other sites More sharing options...
