Ollied Posted January 6, 2010 Report Share Posted January 6, 2010 Hi there, I bought this a few weeks ago and i'm missing the feel of the water bleed in my magura so i was wondering if someone could tell me where abouts the echo TR brake leaks and how this could be solved? Thanks, Ollie. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 6, 2010 Report Share Posted January 6, 2010 Bleed it with water, see where it leaks/see if it does even leak, swap to oil, live with oil or go to a magura? Jobs a goodun? Quote Link to comment Share on other sites More sharing options...
Ollied Posted January 6, 2010 Author Report Share Posted January 6, 2010 (edited) is it possible too take the oil out of the brake.. store it somewhere, then bleed it with water, see if it does leak. if it doesnt leave it in then if not put the oil back in.. or is this also known as being a moron..? Edited January 6, 2010 by Ollied Quote Link to comment Share on other sites More sharing options...
N.Wood Posted January 6, 2010 Report Share Posted January 6, 2010 I guess you could store some oil in a pot, yeah? Quote Link to comment Share on other sites More sharing options...
japslap Posted January 6, 2010 Report Share Posted January 6, 2010 Not sure if this is much help but my first normal echo CNC rim brake leaked from the seals in the callipers, when I'd take the pads out there would be oil on the back of them, I sent it back to tarty after about 2 months and they replaced both the callipers under warranty and re-bled it, never leaked after that. Quote Link to comment Share on other sites More sharing options...
Ollied Posted January 6, 2010 Author Report Share Posted January 6, 2010 I guess you could store some oil in a pot, yeah? would it not contaminate it, or lose compression or anything silly like that,.., Quote Link to comment Share on other sites More sharing options...
scotty007 Posted January 6, 2010 Report Share Posted January 6, 2010 (edited) would it not contaminate it, or lose compression or anything silly like that,.., Asked this question the other day but about echo cnc , but might be some helpfull feed back i there for you on the tr lever to mull over sorry forgot LINKY http://www.trials-forum.co.uk/forum/index....howtopic=146135 Edited January 6, 2010 by scotty007 Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted January 6, 2010 Report Share Posted January 6, 2010 is it possible too take the oil out of the brake.. store it somewhere, then bleed it with water, see if it does leak. if it doesnt leave it in then if not put the oil back in.. or is this also known as being a moron..? Yeah but ud need to put exactly the same amount of oil back into the brake else it wouldnt be a good bleed lol. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 6, 2010 Report Share Posted January 6, 2010 They leak either from the slave or master cylinder. That's probably not too helpful... The more recent brakes are a massive improvement comparing to the first ones. In fact the recent ones have a clean history in my books with the first batch failing at around 30%. But then again if you want to run water, what's wrong with a Magura in the first place? Personally I'd never use anything different. Quote Link to comment Share on other sites More sharing options...
Ollied Posted January 6, 2010 Author Report Share Posted January 6, 2010 Thanks for all your replies! When i first recieved the brake it felt lovely, but after a few rides the tpa has to be screwed in more and more each time, it can't be a leak though because its too little of a loss of oil. Well I think I might try water bleed it tommorow and if not go to hellfrauds and buy a pot of mineral oil and give it a decent bleed as the factory bleed is utter shit. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted January 6, 2010 Report Share Posted January 6, 2010 is it possible too take the oil out of the brake.. store it somewhere, then bleed it with water, see if it does leak. if it doesnt leave it in then if not put the oil back in.. or is this also known as being a moron..? Just buy more oil, give a better bleed? Quote Link to comment Share on other sites More sharing options...
