Onza Comp Review
onza_rip95
Top model in the new range is the Comp, A dual Magura HS33 set up is the default choice of many riders and was first choice here. A very distinctive paint finish of pearl white with blue contrast gives this classy model a real pro feel..
Description
- High quality 20" wheel trials bike from Onza, ideal for fast-learning beginners or intermediate riders.
- High grade 6061-T6 aluminium frame with rear disc mount, integrated chain tensioners and head tube reinforcing gussets.
- Tough Onza cromoly forks with 4-Bolt Magura brake mount and disc brake mount.
- Super powerful Magura HS33 hydraulic brakes front and rear, with CNC machined Tensile Magura Mounts!
- Drilled Onza Skim Rims, 20" front and 19" rear.
- Blue rim tape showing through the holes in the rims sets the colour scheme off really nicely!
- Maxxis Creepy Crawler tyres, 20 x 2.0" front and 19 x 2.5" rear.
- New Onza T-Comp crankset with durable super-thick aluminium alloy bashring.
- Onza bash/ski-plate fitted as standard.
- Onza cromo stem and 'flat' trials handlebar.
- New Onza caged pedals.
- Tensile 60 engagement 18T freewheel fitted to the cranks for great pedalling response and maximum ground clearance, running 18-12 gear ratio.
- Gloss white frame with gloss blue forks and Onza logos.
- Durable K810 Kool chain fitted as standard.
Geometry (to be confirmed)
Wheelbase: 1020mm
Chainstay Length: 362mm
BB Rise: 50mm
Weight: 10.68kg
Reviews
There are currently no product reviews.
NOTE: Reviews may require prior approval before they will be displayed
Write Review
Why have you copied and pasted the spec here?
I havent copied and pasted its not really that bad to know about it and all I did was wrote down the parts.Its just me trying to help.
weight 10.68kg says it all.
What do you mean?
Edited by onza_rip95
I havent copied and pasted it its not really that grad to know about it and all i did was wrote down the parts.Its just me trying to help.
It's copied and pasted straight from Onza/Tartybikes website (or some other). You've added nothing useful to the post so I'm not sure who you're trying to help.
This topic is now closed to further replies.
