Onza Blade Review
onza_rip95
The blade would not seem to be out of place at any local competition or any street ride. The frame is the same as the Pro, The subtle difference between the 2 models is in the braking and rims. If you have heard of bike trials you will more then likely heard of Magura HS33 hydraulic brakes. The Trials riders’ brake of choice for years and used by some of the worlds best riders. The Blade come with a rear Magura HS33 and Onza front duel pull disc brake. The rear rim is has circular drilled holes for weight reduction and aesthetics with front rim having the very distinctive hog holes and side wall drilling.
# Frame: U6 frame with Patented CNC reverse drop out system
# Forks: Cromoly Fork
# Stem: Onza Cromoly
# Handlebars: Onza Cromoly
# Front Brake: Onza Duel pull Disc
# Rear Brake: Magura HS33 Hydraulic Rim
# Brake Levers: Magura
# Rims: Onza Ronnie and Reggie Drilled
# Tyres: Maxxis Creepy Crawler
# Grips Clear Porcipaw XL
# Pedals: Onza Trials Cage
# Colour: Silver
This topic is now closed to further replies.
