Monty
Rob.
I am going to go against the grain and say no. Those cranks don't have many threads, so by using a bash ring, you risk stripping the crank. You maaaay get away with a thin trialtech ti bash, they are about 3mm thick.
Best bet is to put a bash on (or something to the same thickness) and count how many threads you have left, 7 threads should be enough to hold without stripping.
I've got a 231ti bash ring (the newest halfring one) kicking about and its even thinner than the Trialtech Ti ring, you might get away with it. But I dont suppose you will be able to get hold of one easily, I've not seen them for sale anywhere. Personally I would go for stronger cranks. The 221ti cranks are the only cranks that I have ever snapped!
