steve g Posted December 31, 2009 Report Share Posted December 31, 2009 (edited) Hi, ive managed to break a bearing whilst trying to remove it from my hub, leaving the outer ring stuck in my hub does anyone know a good method for removing the bloody thing ? thanks. (its a t-master) Edited December 31, 2009 by steve g Quote Link to comment Share on other sites More sharing options...
TROYston Posted December 31, 2009 Report Share Posted December 31, 2009 This is a right Problem ive had many a time. Best option is to get a dremel tool with the metal grinding attachment thingy and grind into the hub just under the outer ring and get the ring as much as possible. Then get the strongest screw driver and the hammer under what you just ground, When i do this i tend to find that the ring will begin to snap inwards then it comes out easy as. Good Luck. Quote Link to comment Share on other sites More sharing options...
steve g Posted January 1, 2010 Author Report Share Posted January 1, 2010 This is a right Problem ive had many a time. Best option is to get a dremel tool with the metal grinding attachment thingy and grind into the hub just under the outer ring and get the ring as much as possible. Then get the strongest screw driver and the hammer under what you just ground, When i do this i tend to find that the ring will begin to snap inwards then it comes out easy as. Good Luck. Hey, thanks for the advice, managed to get it out. Quote Link to comment Share on other sites More sharing options...
