braderzz.p Posted December 28, 2009 Report Share Posted December 28, 2009 i have try-all croco pads and they wears my grinds smooth even after tarty bike ground my wheel so i have desided to get new pads but what ones ?? Please help ! Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted December 28, 2009 Report Share Posted December 28, 2009 Stop making so many topics! You won't get validated either unless you start spelling properly. Use the spell checker.Anyway What sort of grind do you have and what colour of Croco's do you have? Quote Link to comment Share on other sites More sharing options...
braderzz.p Posted December 28, 2009 Author Report Share Posted December 28, 2009 I have the brown ones. Where do you find the speel checker ? Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted December 28, 2009 Report Share Posted December 28, 2009 Spell checker is the ABC sign with the tick. What sort of grind do you have??? Quote Link to comment Share on other sites More sharing options...
braderzz.p Posted December 28, 2009 Author Report Share Posted December 28, 2009 Spell checker is the ABC sign with the tick. What sort of grind do you have???I run meidium grind Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted December 28, 2009 Report Share Posted December 28, 2009 Are you're pads set up perfectly square? Are you sure your bleed isn't just s**t? Quote Link to comment Share on other sites More sharing options...
braderzz.p Posted December 28, 2009 Author Report Share Posted December 28, 2009 i have a water bleed i am getting it re-bled soon and my brakes seem square to the rim Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted December 28, 2009 Report Share Posted December 28, 2009 (edited) Just wait till tartybikes open. Or ask Adam@TartyBikes or OnzaboyMark Edited December 28, 2009 by onza_ardmair Quote Link to comment Share on other sites More sharing options...
braderzz.p Posted December 28, 2009 Author Report Share Posted December 28, 2009 ok cheers for your help Quote Link to comment Share on other sites More sharing options...
onza rider.. Posted December 28, 2009 Report Share Posted December 28, 2009 tnn lgm pads with a grind *** ! or if you can get some old coust pads and there een better ,, Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted December 28, 2009 Report Share Posted December 28, 2009 Rock Blues are amazing on grinds!!They might not solve the grinds wearing quickly, but they are insane! Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted December 28, 2009 Report Share Posted December 28, 2009 if your grind is going blunt is obviously the rim not the pads Quote Link to comment Share on other sites More sharing options...
rupintart Posted December 29, 2009 Report Share Posted December 29, 2009 if your grind is going blunt is obviously the rim not the pads Coust pads own all other pads. I dunno how a shit bleed would affect how your pads wear, but whatev. Pads being SQUARE to the rim though, will make a HUGE difference in pad life. Quote Link to comment Share on other sites More sharing options...
Borgschulze Posted December 29, 2009 Report Share Posted December 29, 2009 I had 44Tango pads with the Polycarbonate backings most of the summer... those pads wore down a grind way quicker than my Plasmatic and Moe/Spanish Fly pads whatever those were.I'm guessing the TNN LGM pads I just got will wear down a grind even faster. Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 29, 2009 Report Share Posted December 29, 2009 Croco brown pads are relatively hard and i have found them to wear down a grind, but still seem to work well on a dead grind anyway. A shit bleed won't make any difference unless its causing the pistons not to retract properly and leaving the pads dragging on the rim. Quote Link to comment Share on other sites More sharing options...
Filo Posted December 30, 2009 Report Share Posted December 30, 2009 tnn lgm pads with a grind *** ! these are the pads you want.ive been running them for 5 months and the wear is about 40% of original thickness.i used a very coarse grind for 3 months.i built new wheels and use a fine to medium grind and the wear is minimal now and the breaks are preforming much much better.so if you use these pads use a medium grind because you get a better working brake Quote Link to comment Share on other sites More sharing options...
