Lei ke si Posted December 28, 2009 Report Share Posted December 28, 2009 anyone put grease on seal barring headset.. Quote Link to comment Share on other sites More sharing options...
Ashley Sayers Posted December 28, 2009 Report Share Posted December 28, 2009 yess i do Quote Link to comment Share on other sites More sharing options...
dandadude Posted December 28, 2009 Report Share Posted December 28, 2009 Usually the whole point of the bearing being sealed is exactly that. You dont need to grease it as the bearings etc are sealed in and all with its own grease. And just a tip to help you get validated quicker you may want to proof read your posts for spelling etc Quote Link to comment Share on other sites More sharing options...
willdudeXD Posted December 29, 2009 Report Share Posted December 29, 2009 i do, in the little machined part of the frame, just helps it not rust in and get stuck Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted December 29, 2009 Author Report Share Posted December 29, 2009 thanks alot. Quote Link to comment Share on other sites More sharing options...
Skippy Posted December 29, 2009 Report Share Posted December 29, 2009 Packing the headset and steering tube with grease wont harm the performance i do as it acts as a sealant against water etc. Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 29, 2009 Report Share Posted December 29, 2009 Why would you ever grease a sealed bearing headset? It will likely cause more harm then good, collecting dirt in the headset and causing premature wear. Your certainly shouldn't ever grease a steerer tube before installing a headset. Quote Link to comment Share on other sites More sharing options...
Borgschulze Posted December 29, 2009 Report Share Posted December 29, 2009 Greasing the outside of a sealed bearing is common practice.Often reduces creaking sounds if they start to appear.I would only grease integrated headsets though, as removing the bearings of a headset in which they are pressed in is more hassle than it's worth most of the time.Not to mention the fact that if the bearing is pressed in, it's unlikely that it's creaking. Quote Link to comment Share on other sites More sharing options...
