Crank Bolts
Mission Prodigy Trials.
I believe ISIS bottom brackets are either M12 or M15. Not M14 or M15. I think your ZHI bottom bracket is M12, But i'm not certain. Best thing to do is measure the width of the threaded part of you current crank bolts, and if it is 12mm the echo sl bolts won't fit, but if it is 15mm then they will.
Edited by Mikee
I'm running an M14 BB - however, it's a super light ti jobber so that's why.
Just saw a photo of an ISIS BB that's apparently from Zhi, looks like an M12...
Thank you I have now measured the bolts and they are M12, Just curious because I was about to order some Echo Sl bolts which wouldn't have fitted.
Thank you everybody. :D
