315r Posted December 24, 2009 Report Share Posted December 24, 2009 (edited) Hello.I'm very angry confused, yesterday I try to weigh my bike in a person weigher (bad method but I don't have other). Surprising my bike weigh 11,3 Kg!!!! This is to much! moreover in the specifications of the bike in all webs said 9,8.Where the hell is this extra 1,4 Kg ? is to much increase!! It can be posible or just I use a bad method to weigh ? What do you think?Now copy / paste the specifications of my bike from tartybikes web and change my updates in red colour.Frame and Forks- Frame: Yaabaa 1499 with +50 rear disc mount.- Forks: TRY-ALL Alu disc 180mm.Wheels- Front hub: TRY-ALL 'H'100 Disc, 28h- Rear hub: TRY-ALL 'H' 135 Disc, Single Speed 32h- Chain tensioner: TRY-ALL CNC (two black without scoops)- Front rim: TRY-ALL hOle 32mm 28h, drilled- Rear rim: TRY-ALL 47mm 32h, drilled- Spokes: TRY-ALL- Rim tape: TRY-ALL rear / trialtech front- Inner tube (front): TRY-ALL Specialized thin- Inner tube (rear): TRY-ALL Kenda- Front tyre: TRY-ALL STIKY 26X2.00 White ones- Rear tyre: TRY-ALL STIKY 26X2.50 White onesBrakes- Front brake: Magura Louise 180mm - Rear brake: Magura HS33- Brake pads: TartyBikes High Performance COUST Pads- Brake clamps: Magura try-all- Try-all boosterDrivetrain- Cranks: TRY-ALL ISIS 175mm, Silver- Freewheel: TRY-ALL 108.9 18T- Chain: TRY-ALL reinforced, light KMC cool chain reinforced- Rear Sprocket: TRY-ALL Single speed 15T, chromed and drilled- Pedals: TRY-ALL Dual Cage, Black- Bottom bracket: TRY-ALL First ISIS 127.5mm- Bashring: TRY-ALL Symetrik, BlackSteering- Headset: TRY-ALL- Stem: TRY-ALL 125mm x 25° silver- Grips: TRY-ALL rubber, black CHORRILLAS- Handlebars: TRY-ALL Punching Trialtech low rise bar- Steerer: 1,5 Cm with carbon trialtech spacers.Extra: protection of frame with a piece of hose in rear /bottom part of frame. not to much.Weight (including pedals)- 9.8kg / 21.61lbs 11,3Kg Edited December 25, 2009 by 315r Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted December 24, 2009 Report Share Posted December 24, 2009 Seems a massive amount of weight MY zona zenith(2.2kg frame) was at it's heaviest only 11.2kg, and that was with a rear echo 07 rim, echo cnc cranks, gigapipe bb and 203 BB7 Try weighing again? Quote Link to comment Share on other sites More sharing options...
Ollied Posted December 24, 2009 Report Share Posted December 24, 2009 Just did mine at got 8747gI shall weigh my bike later, but at a guessInnertubes + Air = a bit.some of the products weren't weighed efficently. Quote Link to comment Share on other sites More sharing options...
nyoli Posted December 24, 2009 Report Share Posted December 24, 2009 it happened the same with the hydroxx 2. there's an article at tribalzine Quote Link to comment Share on other sites More sharing options...
315r Posted December 24, 2009 Author Report Share Posted December 24, 2009 (edited) it happened the same with the hydroxx 2. there's an article at tribalzine Do you have localized this article?Can you post it here?This could be truth because the only thing that is different between yaabaa 1499 and Hidroxx 2 is the frame. Edited December 24, 2009 by 315r Quote Link to comment Share on other sites More sharing options...
Davetrials Posted December 24, 2009 Report Share Posted December 24, 2009 Are you sure cos you weighed it in the worse way possible.weigh it properly just to check.and more so can you even feel that its ways 11kg?or are u just being picky? Quote Link to comment Share on other sites More sharing options...
totaltrials Posted December 24, 2009 Report Share Posted December 24, 2009 (edited) Weigh it properly, using more accurate scales ?¿?¿?¿?¿?¿?¿? Edited December 24, 2009 by totaltrials Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 24, 2009 Report Share Posted December 24, 2009 If it is indeed the correct weight of your bike then this is evidence to support the idea that "20g here 30g there" bike diet is correct.A good example of variation between different individual items of the same product is tyres.I have a try all sticky mod rear tyre that should weigh about 1050g or thereabouts new.Now mines as bald as a coot and therefore should weigh a good bit less.Well it doesn't.I weighed it when I changed it yesterday and it weighed 1200g who knows what it weighed new probably 1500g.So if you have extreme of discrepancy in the claimed weight and actual weight in two tyres then you are looking a 1kg just from the tyres.Add that to 10g here and there over the whole bike and it'll soon add up I suppose. Quote Link to comment Share on other sites More sharing options...
Rush Posted December 24, 2009 Report Share Posted December 24, 2009 Air = a bit. Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 24, 2009 Report Share Posted December 24, 2009 No way that weighs 11,3kgs. Thats roughly how much a Deng bike on Urban parts would weigh.Seriously, 11,3 is insanely heavy for a trials bike. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 24, 2009 Report Share Posted December 24, 2009 If you only think it's heavy after seeing the weight, you're a fanny. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted December 24, 2009 Report Share Posted December 24, 2009 Lmao, best topic of 2009. Quote Link to comment Share on other sites More sharing options...
chris4stars Posted December 25, 2009 Report Share Posted December 25, 2009 (edited) I'm very angry, yesterday I try to weigh my bike in a person weigher (bad method but I don't have other). Surprising my bike weigh 11,3 Kg!!!! This is to much! moreover in the specifications of the bike in all webs said 9,8.Its shocking, when i weighed myself at home on some £20 scales from argos.....i was 74kg, then i went to the gym and used some accurate scales and it told me i was 78kg! dont worry...after getting all angry and flustered, i complained to the gym..came straight back home, found an internet forum and asked everyone what happened*edit - phew...i just weight myself properly on scales i knew were exactly accurate, and it turns out..i was around 78kg - i then realised, that i shouldnt get so worked up on a number some scales give me if im happy with things anyway Edited December 25, 2009 by chris4stars Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 25, 2009 Report Share Posted December 25, 2009 lmaao that was f**king awesome! Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted December 25, 2009 Report Share Posted December 25, 2009 Its shocking, when i weighed myself at home on some £20 scales from argos.....i was 74kg, then i went to the gym and used some accurate scales and it told me i was 78kg! dont worry...after getting all angry and flustered, i complained to the gym..came straight back home, found an internet forum and asked everyone what happened*edit - phew...i just weight myself properly on scales i knew were exactly accurate, and it turns out..i was around 78kg - i then realised, that i shouldnt get so worked up on a number some scales give me if im happy with things anywaysuperb, pretty much what i was trying to achive, but really couldnt be arsed haha. Quote Link to comment Share on other sites More sharing options...
IOLO Posted December 25, 2009 Report Share Posted December 25, 2009 iv discovered that if i weight my self, then eat some food.. my weight increases by the amount of food i ate !!!WFT !!!!! 111111this also applies to when i just put the food in my pocket ,, the weight is still added !!! ARGH ! im so angry !iv decided to re weigh the food and drill holes in my pockets..but my drill is too heavy. gr............please..just...go for a bike ride. Quote Link to comment Share on other sites More sharing options...
315r Posted December 25, 2009 Author Report Share Posted December 25, 2009 (edited) I can't understand why people start to joking with this topic, I just was concerned after weigh my bike in not apropiated weigher and just want an opinion if this weigh can be possible. For sure the option that i used to weigh my bike is not apropiated but i don't have other and is not for that people start to joke with this.Anyway, thanks for apropiated comments and for all others you can continue joking if that makes you happy. For sure, you are extremelly clever and never ask inapropiated questions in forums. At least now I know what i have to do:1- Weigh again in apropiated scale.2- Don't start a topic in this forum unless it was extremelly clever, if not some people may feel offended....... EDIT: maybe the expresion "i'm angry" in the first topic is not correct maybe is better "I'm confused" or "I'm concerned" if is it the starter of jokes, but excuse me, english is not my mother language like you can see.EDIT 2: i have modified the first topic.EDIT 3: I'm very happy with my bike, i like it to much, I just was confused with the first measurement. Edited December 25, 2009 by 315r Quote Link to comment Share on other sites More sharing options...
chris4stars Posted December 25, 2009 Report Share Posted December 25, 2009 since its christmas, i'll try to take this seriously and be of some sort of help this time....how is the weight increase possible? im not sure..you have the bike, and it would be alot easier to do a little homework firsttarty bikes seems to have the weight of almost all of thier products on thier website...if they dont have one you need, im sure they would have something similar, and this could give you a good idea of the weights certain components should bealot of people have kitchen scales that go up to about 5kg..hopefully you or a friend will have a set?with the scales and that info, you can work out what your wheels should weigh..and check each one with relative accuracy, then check other parts and probably work most of this conundrum out yourself Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted December 25, 2009 Report Share Posted December 25, 2009 please..just...go for a bike ride.who gives a shit if your bike is 3 kg heavier. If it bothers you that much (this goes for anyone btw) go 'pump some iron' seriouslywhat happened to when it was about riding the bike, not weighing it?! Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 25, 2009 Report Share Posted December 25, 2009 my bikes 11.5kg Quote Link to comment Share on other sites More sharing options...
jambo Posted December 25, 2009 Report Share Posted December 25, 2009 my 1499 is built up with a pro2 and pashley forks and weighs 10.7kg Quote Link to comment Share on other sites More sharing options...
315r Posted December 25, 2009 Author Report Share Posted December 25, 2009 (edited) my bikes 11.5kg my 1499 is built up with a pro2 and pashley forks and weighs 10.7kgReally? maybe my measurement was more accurate than I thought....Thanks for the info Edited December 25, 2009 by 315r Quote Link to comment Share on other sites More sharing options...
315r Posted December 25, 2009 Author Report Share Posted December 25, 2009 since its christmas, i'll try to take this seriously and be of some sort of help this time....how is the weight increase possible? im not sure..you have the bike, and it would be alot easier to do a little homework firsttarty bikes seems to have the weight of almost all of thier products on thier website...if they dont have one you need, im sure they would have something similar, and this could give you a good idea of the weights certain components should bealot of people have kitchen scales that go up to about 5kg..hopefully you or a friend will have a set?with the scales and that info, you can work out what your wheels should weigh..and check each one with relative accuracy, then check other parts and probably work most of this conundrum out yourselfThanks to try to understand me even if just because it's christmas.My intention is only ask if my measurement can be posible because at first seems to much, no more. I'm very happy with my bike and it rides amazing, But just because this is a trial forum i though that can be a interesting topic to coment...If Ali C and Jambo said that his bikes have more or less the same weigh I'm more unconcerned Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 26, 2009 Report Share Posted December 26, 2009 well, maybe I wasn't being quite honest My comp bike weighs around 10kg, thats with some super light parts (ti bb, pedals axles trialtech sl rims ect) but also some heavier stuff too (rain king rear tyre, 200mm rotor, vee brake with adaptor and booster).However, my street bike weighs 11.5kg with no light weight parts and a saddle, but I have now taken the brakes off and fitted some lighter tyres and its now around 10.3kg.Stick with the heavier weight for now, but if you do comps next year, you could put some lighter parts on before them. Quote Link to comment Share on other sites More sharing options...
TROYston Posted December 26, 2009 Report Share Posted December 26, 2009 iv discovered that if i weight my self, then eat some food.. my weight increases by the amount of food i ate !!!WFT !!!!! 111111this also applies to when i just put the food in my pocket ,, the weight is still added !!! ARGH ! im so angry !iv decided to re weigh the food and drill holes in my pockets..but my drill is too heavy. gr............please..just...go for a bike ride.hahah. don't forget to drink helium. Quote Link to comment Share on other sites More sharing options...
