multi tasking male Posted December 22, 2009 Report Share Posted December 22, 2009 i have been looking at rear huubs nd have noticed that there are two differences. What the difference between a fixed hub and free hub ?what the difference in a 116mm hub or a 135mm hub ? what hub would you use on a single speed 24' ? Quote Link to comment Share on other sites More sharing options...
mtnbikerfred Posted December 22, 2009 Report Share Posted December 22, 2009 (edited) 1) A "fixed hub" is for running s front freewheel with a "fixed cog" and lockring on the hub.2) A "freehub" is splined to run (one or more) "cassette style cogs" and has an internal freewheel3) 116mm and 135mm are the distance between the dropouts. IMHO wider is better, mainly because wider flanges on single speed freehubs mean stronger wheels.4) It depends what is available on the frame you like, which will ultimately be better for YOU (even though all your jealous friends will tell you it sucks)Cheers Edited December 22, 2009 by mtnbikerfred Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted December 23, 2009 Report Share Posted December 23, 2009 For a 24, I'd run a king or echo sl freewheel with an echo tr hub.You'll need a 135mm hub for sure though. Quote Link to comment Share on other sites More sharing options...
chronic Posted December 24, 2009 Report Share Posted December 24, 2009 Alex, have you run that freewheel? A friend of mine has one, it seems dodgy. It skipped alot at the start, and after a rebuild it still skips. Just wondering if you have had luck. Quote Link to comment Share on other sites More sharing options...
