joshlyd1 Posted December 22, 2009 Report Share Posted December 22, 2009 Right i have a Koxx fluro yellow wheel with i think its a 135 hub or something , well i have lost the things that cover the bearings and help clamp to the dropout does anyone have any i can buy ?? preferably in brum tomorrow is it safe to run on the bolts if the spacer things are too big ? what size are they so i can run up my LBS in the morning to get some ? please could someone post a pic of the wheel because i cant seem to find any pictures , its 135 spacing fixed thanks please help thanks in advance Josh Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted December 22, 2009 Author Report Share Posted December 22, 2009 anyone ??? Quote Link to comment Share on other sites More sharing options...
sstein Posted December 23, 2009 Report Share Posted December 23, 2009 Right i have a Koxx fluro yellow wheel with i think its a 135 hub or something , well i have lost the things that cover the bearings (do you mean the cones or the dust covers or the seals or the lockrings...?) and help clamp to the dropout does anyone have any i can buy ?? preferably in brum tomorrow is it safe to run on the bolts if the spacer things are too big ? (what bolts/spacers?) what size are they so i can run up my LBS in the morning to get some ? (link to the hub online or photos?) please could someone post a pic of the wheel because i cant seem to find any pictures (why can't you?) , its 135 spacing fixed thanks please help thanks in advance JoshBy the sounds of it (i think) you have lost the dust covers (the metal rings with a slight dish that sit around the cone). These are normally specific to the hub. Your best bet would be to go to a couple of bike shops and see if they have anything lying around that fits. You can use the hub without them but I would not really recommend it as dirt will get in and make the bearings feel like crap and if the cones come slightly loose you will lose all of the bearings.Maybe try giving some more detailed information if you want more useful help! Quote Link to comment Share on other sites More sharing options...
joshlyd1 Posted December 23, 2009 Author Report Share Posted December 23, 2009 ahh ok well its kind ofhard for me to explain lets take the onza discless hub for instance the black shiney cup thingys on each side of the bolt are what im missing on my koxx wheel if that makes any sense i tried it without but my frame flexed quite abit and even with both bolts fully tight it wasnt as tight as it is ment to be this is so anoying i built up a whole stock yesterday and went around my LBS to get bits but i just missed these two tiny things "/ Thanks Josh Quote Link to comment Share on other sites More sharing options...
