smith.93 Posted December 22, 2009 Report Share Posted December 22, 2009 What is the difference to the brake quality between a CNC hydraulic brake and a normal hydraulic brake? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted December 22, 2009 Report Share Posted December 22, 2009 vast Quote Link to comment Share on other sites More sharing options...
JT! Posted December 22, 2009 Report Share Posted December 22, 2009 If you're talking about the difference's between maguras and the echo rim breaks, there really isn't much difference with regards to performance.You really want to be looking at the brake as a whole.CNCing is an expensive process that put the price of parts up ending up with something that's slightly better but much more expensive. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted December 22, 2009 Report Share Posted December 22, 2009 If you're talking about the difference's between maguras and the echo rim breaks, there really isn't much difference with regards to performance.You really want to be looking at the brake as a whole.CNCing is an expensive process that put the price of parts up ending up with something that's slightly better but much more expensive.but will last for alot longer so is worth it Quote Link to comment Share on other sites More sharing options...
mtnbikerfred Posted December 22, 2009 Report Share Posted December 22, 2009 CNC = Computerized Numeric Controlled machining....In modern manufacturing such as with bicycle components, it is LESS EXPENSIVE to CNC many components where there are critical tolerances (like the bores, mounting surfaces and interfaces between moving parts) on hydraulic brakes. It'd cost a fortune and take for ever to manually machine those one at a time, and if you chow just ONE cut, you throw away not only the material, but the time you put into machining every cut before it. Even the cheapest, pot-metal parts often have CNC'd dimensions. I hate that terms such as "CNC" and "billet" are thrown around to imply some sort of quality, when in reality, it mostly represents "knock-off-Gucci" Fred. Quote Link to comment Share on other sites More sharing options...
