ONZA_TRIALS Posted December 20, 2009 Report Share Posted December 20, 2009 Hi i just waterbleed my Back brake and i was wondering do you have to put antifreeze or di icer in ? thanks Jack Quote Link to comment Share on other sites More sharing options...
Chris Elson Posted December 20, 2009 Report Share Posted December 20, 2009 ive used ready mixed putoline coolant.... have to put a tad more water in though. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted December 20, 2009 Report Share Posted December 20, 2009 If the temperature drops below -4 then the anti-freeze will freeze :|. It happened to me today. Both brakes were rock solid. Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted December 20, 2009 Report Share Posted December 20, 2009 Will the brake freezing break the brake in any way? Quote Link to comment Share on other sites More sharing options...
Borat Posted December 20, 2009 Report Share Posted December 20, 2009 If the temperature drops below -4 then the anti-freeze will freeze :|. It happened to me today. Both brakes were rock solid.How much antifreeze did you use? Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted December 20, 2009 Author Report Share Posted December 20, 2009 Forgot to put it in , so i have to re bleed it and put Quite a bit in but not to much . Quote Link to comment Share on other sites More sharing options...
max-t Posted December 20, 2009 Report Share Posted December 20, 2009 Will the brake freezing break the brake in any way?No. Just put it by a radiator after. Quote Link to comment Share on other sites More sharing options...
trialsrider.chris Posted December 20, 2009 Report Share Posted December 20, 2009 wudnt it just be best to use dot 4 ? Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted December 20, 2009 Author Report Share Posted December 20, 2009 wudnt it just be best to use dot 4 ?Water Bleeding is so much easier , Also the lever is easier to pull wich decreases arm pump Quote Link to comment Share on other sites More sharing options...
trialsrider.chris Posted December 21, 2009 Report Share Posted December 21, 2009 Water Bleeding is so much easier , Also the lever is easier to pull wich decreases arm pumpahhh i see thanks for the tip . learn something new every day Quote Link to comment Share on other sites More sharing options...
sstein Posted December 21, 2009 Report Share Posted December 21, 2009 wudnt it just be best to use dot 4 ?never use dot fluid for a magura as they are designed for mineral oil and dot fluid will rot the seals. Anyway if you could use dot fluid why not use dot 5.1 instead of 4? Quote Link to comment Share on other sites More sharing options...
ONZA_TRIALS Posted December 21, 2009 Author Report Share Posted December 21, 2009 ahhh i see thanks for the tip . learn something new every day Thats ok dude ... Quote Link to comment Share on other sites More sharing options...
315r Posted December 21, 2009 Report Share Posted December 21, 2009 Here in Spain some people are talking about Shimano brake fluid "Red one" That seems like it's more liquid than Maguras royal blood.Because I'm not interested to bleed my system with water, this solution can be good one.What do you think?Somebody have test this brake fluid for HS33?? Quote Link to comment Share on other sites More sharing options...
Mockett Posted December 21, 2009 Report Share Posted December 21, 2009 but when water freeze's it expands shurly this will damage the brakes Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted December 21, 2009 Report Share Posted December 21, 2009 what is this water bleeding, what do u do replace oil for water ?, that might sound dumb but im new lol Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted December 21, 2009 Report Share Posted December 21, 2009 but when water freeze's it expands shurly this will damage the brakesYeh that was my thinking, and when it melts would the stuff be looser? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 21, 2009 Report Share Posted December 21, 2009 but when water freeze's it expands shurly this will damage the brakesYeh that was my thinking, and when it melts would the stuff be looser?The water expands and just pushes your pads out slightly. No harm done There's not really all that much fluid in your brakes, so there's not really much to expand meaning that even if it full-on freezes it'd be no different than squeezing your brake lever a bit.For the antifreeze, you only need a bit because again there's not much water. Once it's bled with water, it should be pretty easy to bleed a bit of antifreeze into the system if you've not done it already. Quote Link to comment Share on other sites More sharing options...
leotrialp Posted December 21, 2009 Report Share Posted December 21, 2009 Hi i just waterbleed my Back brake and i was wondering do you have to put antifreeze or di icer in ? thanks Jackremember than the antifreeze is more corrosive than the water, so, i don´t think than that can be a good idea... Quote Link to comment Share on other sites More sharing options...
315r Posted December 21, 2009 Report Share Posted December 21, 2009 remember than the antifreeze is more corrosive than the water, so, i don´t think than that can be a good idea...Excuse me, I'm not agree. Antifreeze is not more corrosive than water.Anyway, what the people think about Shimano brake oil? I'm going to create a topic in members chat talking about that. Quote Link to comment Share on other sites More sharing options...
weebryan Posted December 22, 2009 Report Share Posted December 22, 2009 -7 no effect, antifreeze from work PGXL diesel engine coolant used this for the last 3 years in same brake PGXL Info Quote Link to comment Share on other sites More sharing options...
Nyczek Posted December 22, 2009 Report Share Posted December 22, 2009 50% Vodka 50% Wather. If you sure that temperature will bi higher than -10 you can mix it 4:6 Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted January 3, 2010 Report Share Posted January 3, 2010 whats water bleeding ? Quote Link to comment Share on other sites More sharing options...
scotty007 Posted January 3, 2010 Report Share Posted January 3, 2010 whats water bleeding ? Come on fella did you read the topic or just post at the end . Replaces your oil bleed brake with water = Better brake responce and feal. Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted January 3, 2010 Report Share Posted January 3, 2010 what and then leave it in im guessing, so you replace oil for water. Quote Link to comment Share on other sites More sharing options...
scotty007 Posted January 3, 2010 Report Share Posted January 3, 2010 what and then leave it in im guessing, so you replace oil for water. yep just bleed your brake with water or water/antifreeze is best in this weather all good ! Quote Link to comment Share on other sites More sharing options...
