Nyczek Posted December 20, 2009 Report Share Posted December 20, 2009 My break i good for street, but in natural it's too week.There will be magura slave cylinders.What is the stronges system?Magy 05+ 4 finger lever Magy 05+ with echo CNC lever Echo TR I use water.I'm looking for max bite, can be without modulation. Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 20, 2009 Report Share Posted December 20, 2009 theres no such thing as a strongest rim brake depend what pads, rim surface etc... Quote Link to comment Share on other sites More sharing options...
Nyczek Posted December 20, 2009 Author Report Share Posted December 20, 2009 (edited) ...So what lever will give max bite power?I using rockman pads, in future rockman cnc if it make a diffrence* Sorry for my english. Edited December 20, 2009 by Nyczek Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 20, 2009 Report Share Posted December 20, 2009 have you got a deep grind for those rockman pads Quote Link to comment Share on other sites More sharing options...
Nyczek Posted December 20, 2009 Author Report Share Posted December 20, 2009 (edited) Yes, but i have got urban rim... so it's not durability for more than month.I used it with tar too.Break is good in normal ride like i said but on stones or drops it stops hold rim.Don't have air in system, have koxx XTP. It's stiff so i don't use break booster. My break system :Echo TR lever ( quite new )Standard hoseMagura cylinders, one of them can work better. I don't know, I thinking that booster is not nessesery because lever is stiff. Edited December 20, 2009 by Nyczek Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 20, 2009 Report Share Posted December 20, 2009 Use an 05 with a 4 finger lever and you get ALOT more leverage! Quote Link to comment Share on other sites More sharing options...
sstein Posted December 21, 2009 Report Share Posted December 21, 2009 If everything is set up right and you are using decent pads on a grind then you should have no problems. Try some different pads (phat pad or rock blues have worked well for me) and make sure everything is set up right. Quote Link to comment Share on other sites More sharing options...
willdudeXD Posted December 21, 2009 Report Share Posted December 21, 2009 get a booster too! :3 Quote Link to comment Share on other sites More sharing options...
onza rider.. Posted December 30, 2009 Report Share Posted December 30, 2009 the best brake setup out there is probs 05 maggy with 4 finger leaver water bleed and some old coust or the oringal coust or tnn lgm pads with a nice sharp grind, or if you are that botherd you could also use a monty hose splitter hope that help hoby Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 30, 2009 Report Share Posted December 30, 2009 vee brakes are the most powerful, but have the least bite.What do you want all that bite for? think about all the times your depending on the brake, when is power the most important? Stopping the bike forwards when going on the back wheel? Or when going backwards when landing gaps, taps, hooks, and just about every other move out there? vee brakes have the most holding power, power when you need it most. Quote Link to comment Share on other sites More sharing options...
Filo Posted December 30, 2009 Report Share Posted December 30, 2009 i agree with ali c.ive used vee's and magura.the vee's hold heaps better.i run mine so the lever pulls in more.after the levers moved past the pivot point i feel that they lock,i think thats why they hold well. i like the bite of the magura's they also have a nice hold. if you want maximum bite i say new style magura's,4 finger lever,tnn clamps/booster combo and tnn lgm pads with a fine to medium grind.i cant believe how much bite they have,its insane. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 30, 2009 Report Share Posted December 30, 2009 vee brakes are great! they perform fairly well even with the standard pads they come with Quote Link to comment Share on other sites More sharing options...
robotrhys Posted December 30, 2009 Report Share Posted December 30, 2009 I would go for echo rear brake with plazmatic, koxx browns or heatsink pads and a grind. Win, win, win. Please vote for me to become full member, thanks! Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 31, 2009 Report Share Posted December 31, 2009 I would go for echo rear brake with plazmatic, koxx browns or heatsink pads and a grind. Win, win, win. Please vote for me to become full member, thanks! No because you asked and the post wasn't that great. Your set up is pretty much spot on. (As far as maggies go.) You may want to try cleaning your rim or new pads. Even with a frame you think is rigid a booster may help and is always worth a try. Quote Link to comment Share on other sites More sharing options...
