Snail Cams + Chain Tugs
LazyMonkey
complete beginner here..bought a monty 220 hydra a couple months ago...took my rear wheel off to grind today, and ama bit perplexed now that i am putting it back on...there are snail cams and chain tugs on it, i figured it would be no problem but when it came time to throw it all together im a bit confused..
when using snail cams AND chain tugs, do the cams stay on the inside of the frame? anyone have any good pics of their own snail cam/.chain tug setup?
The cams go inside and i would not bother with the chain tugs (Y)
Edited by skinny paul
Ermmm, Monty frames were designed with 113mm spasing, which means that cams go outside. You can check photos of almost any monty and you'll see cams outside.
Or old monty's didn't have that?
Edited by MiuSliS
