trialsalot Posted December 18, 2009 Report Share Posted December 18, 2009 beat me too it ads you mo fo! Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted December 18, 2009 Author Report Share Posted December 18, 2009 It does work. If you lace the wheel on the disc side with all 'heads out' that gives enough clearance.Thanks but dose this not make wheel weaker more flex?? Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted December 18, 2009 Report Share Posted December 18, 2009 Thanks but dose this not make wheel weaker more flex??Would you rather have a wheel that goes round or more flex? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 18, 2009 Report Share Posted December 18, 2009 I ran a wheel like that not so long ago and it was fine. I don't know if Ads has it on his current rear wheel, but he had it on his old back wheel (I say 'old', nothing Ads ever has really has a chance to get 'old' ) and again you can't notice any flex at all. 19" wheels are so small you just can't really feel it at all, in the same way that on a 26" bike you can feel the wheel flex if you run a disc but you can't on a mod. Also, it means you can actually ride your bike: Win. Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted December 18, 2009 Author Report Share Posted December 18, 2009 well wht i have done is put a washer in hub so it moves it over then washers in the disc rotor.... works fine but seems abit... Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted December 18, 2009 Report Share Posted December 18, 2009 Cos its a rockman, clearly I ran a wheel like that not so long ago and it was fine. I don't know if Ads has it on his current rear wheel, but he had it on his old back wheel (I say 'old', nothing Ads ever has really has a chance to get 'old' ) and again you can't notice any flex at all. 19" wheels are so small you just can't really feel it at all, in the same way that on a 26" bike you can feel the wheel flex if you run a disc but you can't on a mod. Also, it means you can actually ride your bike: Win.Ive never been on a mod double disk bike what rear wheel doesnt flex, when you preload 'properly' you can feel it a mile off, espesh with shitty flexy frames aswell, ive had it before when the tyre has rubbed on the frame it was so bad, this was a double disk hydroxx or xtp or something. Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 18, 2009 Report Share Posted December 18, 2009 Sounds like you need to ride a bike with wheels that are maintained. The only reason you'd ever feel flex that badly was if the spokes were loose as f**k (I've felt that before on bikes with rim brakes with 'normally' laced wheels, it was just that the spokes were loose). You seriously need to try out my bike or Adam's bike before you make claims like that...EDIT: Probably a good reason to not buy 'shitty flexy frames' too. My Lynx doesn't really appear to have any problems, but it's got a pretty well reinforced disc mount. Quote Link to comment Share on other sites More sharing options...
TROYston Posted December 18, 2009 Report Share Posted December 18, 2009 You might need the neon hub bud, apparently works perfect? Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted December 18, 2009 Report Share Posted December 18, 2009 You're bikes f**ked Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 18, 2009 Report Share Posted December 18, 2009 You're bikes f**kedWhy in every post I see do you act like a twat? Go back to NMC. Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted December 18, 2009 Author Report Share Posted December 18, 2009 GOT IT WORKING Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 18, 2009 Report Share Posted December 18, 2009 You're bikes f**kedSo helpful yet so eloquent.Edit: Actually on second thoughts that's grammatically poor and completely pointless .Edit 2:GOT IT WORKINGRebuilt rear wheel? Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted December 18, 2009 Author Report Share Posted December 18, 2009 So helpful yet so eloquent.Edit: Actually on second thoughts that's grammatically poor and completely pointless .Edit 2:Rebuilt rear wheel?no i broke apart a old chain and used the washer things and wahsers for my rotor then put another ockman washer hub thingo on the disc side to shift wheel over seems to work ok Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 18, 2009 Report Share Posted December 18, 2009 no i broke apart a old chain and used the washer things and wahsers for my rotor then put another ockman washer hub thingo on the disc side to shift wheel over seems to work ok Sounds sketchy as!! I had the same problem trying to run a Magura Marta on the first Echo EM2 in the country back in ~2002. Tried everything I could but ended up just swapping the brakes for the original single piston Louises... Quote Link to comment Share on other sites More sharing options...
BigAl Posted December 18, 2009 Report Share Posted December 18, 2009 GOT IT WORKING Monster. Quote Link to comment Share on other sites More sharing options...
CalopS Posted December 18, 2009 Report Share Posted December 18, 2009 (edited) GOT IT WORKINGLooks really nice. Get some proper pics up soon! Edited December 18, 2009 by CalopS Quote Link to comment Share on other sites More sharing options...
