ogre Posted December 17, 2009 Report Share Posted December 17, 2009 (edited) My bike is far to heavy! and so am I where am i going wrong at keeping the weight down (on the bike) i'm open to all suggestions of going lighter, but i don't want to compromise on strength massively (i'm 108kgs )Bold stuff is not changingFull Spec:Frame: Simtra (changing to a speedrace in the new year)Fork: echo Urban vee/discHeadset: KingBB: Truvativ Gigapipe this-unDrive:Cranks: middleburns, cloud9 bashPedals: V8sTensioner: tryall rohloff copychain: trialtech liteWheels:rearPro2echo urban rim (thinking about single walling it, how much weight will i loose?) or would it be better to save time and run something lighter?maxxis minion 2.35 dual plyDH tube (possibly overkill with a dua ply tyre?)frontpro2tryall rim (f**ked so this needs replacing soon, will go for a tryall h0le rim, or trialtech square holed)Specialised eskar tyre (probably go for a continental 2.2)Braking:sd7 leverssd7 rear veebb7 front disc (185mm) changing to a vee when it's dry thoughheatsink yellowsZOO! bars, ZOO! mod stem (i'm prety big and it rides nice, sucky for wheel swaps though )suggestions please! nothing that'll compromise strength to much, or rape my wallet i'm not much of a go-big rider but i'm heavy enough to test bits Edited December 17, 2009 by ogre Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 17, 2009 Report Share Posted December 17, 2009 Forks anything lighter.Tyres, go continental both ends.Tubes get some maxxis super light tubes, they wont pinch as much as you think.It does look as all your weight is in your tyres.The front rim may also help, you could concider a matching rear. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 17, 2009 Author Report Share Posted December 17, 2009 urbans are the lightest forks i'll ride; there only 100g more than Echo SL forks, the 6th lightest tarty sell and the price/weight/strength seems right (plus i only bought them a month ago)will a 2.4 protection mountain king fit a simtra ok? Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted December 17, 2009 Report Share Posted December 17, 2009 I'd say change bb, giga pipes are heavy. Definitely tyres, also get rid of the echo urban rim (even if you switch to try-all double wall, it still weighs ~100g less, not even talking about single wall rims,so it's worth after all). I'd also say zoo parts are heavy, change bars at least (in my opion zoo bars are rubbish anyway).There are many areas where to can reduce weight of the bike, but that usually comes with high price. Good luck. Quote Link to comment Share on other sites More sharing options...
Mission Prodigy Trials. Posted December 17, 2009 Report Share Posted December 17, 2009 Frame: SpeedraceFork: Try-All Headset: Chris KingBB: Crankbrothers Cobalt TI.Drive:Cranks: middleburns, cloud9 bashPedals: Trials-Tech Magnesium ( Possible TI axel for less weight )Tensioner: try-all rohloff copychain: trialtech liteWheels:rearPro2echo urban rim (thinking about single walling it, how much weight will i loose?) or would it be better to save time and run something lighter?maxxis minion 2.35 dual plyDH tube (possibly overkill with a dua ply tyre?)frontpro2tryall rim (f**ked so this needs replacing soon, will go for a tryall h0le rim, or trialtech square holed)Specialised eskar tyre (probably go for a continental 2.2)Braking:sd7 leverssd7 rear veebb7 front disc (185mm) changing to a vee when it's dry thoughheatsink yellows The small changes I made may be ok. Quote Link to comment Share on other sites More sharing options...
onzatrip Posted December 17, 2009 Report Share Posted December 17, 2009 Frame:Speed raceFork: echo Urban vee/discHeadset: KingBB: Truvativ Gigapipe this-unDrive:Cranks: middleburns, cloud9 bashPedals: single caged onzasTensioner: tryall rohloff copychain: trialtech liteWheels:rearPro2echo urban rim single walled ive done it saved bout 100g ishmountian king tyres i love mineDH tube (possibly overkill with a dua ply tyre?)frontpro2trialtech squaremountian kingBraking:sd7 leverssd7 rear veebb7 front disc (185mm)heatsink yellowsZOO! bars, trialtech stem Quote Link to comment Share on other sites More sharing options...
tmusson Posted December 17, 2009 Report Share Posted December 17, 2009 those cloud 9 bashrings are unnecesarily heavy bin it and get this http://www.tartybikes.co.uk/product.php?pr...p;category_id=1 Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 17, 2009 Report Share Posted December 17, 2009 Just wait until you get your frame sorted 1st before you start spending. The difference is possibly 600g, which'll make a big difference. Then to get it really light- tyres, rear rim, BB. That's pretty much it. Mod stem can't be doing you any good either. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 17, 2009 Author Report Share Posted December 17, 2009 i likes my mod stem haha. i'm not changing my forks, there only a month old and there vee friendly and beefy and strong plus they look strong. Quote Link to comment Share on other sites More sharing options...
IOLO Posted December 18, 2009 Report Share Posted December 18, 2009 get a die grinder in one handa drill in the otherand get a good run up Quote Link to comment Share on other sites More sharing options...
Token Posted December 18, 2009 Report Share Posted December 18, 2009 DH TUBE!Shave 300 grams there for a fiver! Quote Link to comment Share on other sites More sharing options...
