Spoke Length And Wheel Builds
rab shropshire
Hi all I have a bit of a problem at the minute, I need to build my old onza hog rim onto my front wheel.
here are the details
old rim is a standard try-all circle drilled rim runing on a hope hub
new rim is a standard t-pro rim
my question is will I need new spokes because it is a different rim or will it work just the same.
Thanks for all your help in advance
just had a look on tarty and the erd for both rims is 392mm does this mean it will work
Edited by rab shropshire
Why are you downgrading to a t-pro rim? lol
Because my try-all rim is mashed up and I have a t-pro one lying around its just a fix until I get the money for a new one
I have the same problem... but with a TR hub and a Tryall rim (rear). 116mm
Anyone has the spoke lenght?
phone tartybikes they will square you away with the spoke length you need
Hold them side by side - if the new rim looks to be the same diameter the existing spokes will almost certainly fit. A handy technique for transferring the spokes is to slacken the spokes in the current build, line up the valve holes in the rims, tape them together and swap each spoke to its corresponding hole in the new rim.
