zoo 06 Posted December 9, 2009 Report Share Posted December 9, 2009 i need to bleed my magura front disk with water, is it kind of the same way you would do hs33.please help. thanks Quote Link to comment Share on other sites More sharing options...
315r Posted December 9, 2009 Report Share Posted December 9, 2009 i need to bleed my magura front disk with water, is it kind of the same way you would do hs33.please help. thanksYou don't have to bleed disk brakes with water. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 9, 2009 Author Report Share Posted December 9, 2009 You don't have to bleed disk brakes with water.i knw but i want to thou. can u do it Quote Link to comment Share on other sites More sharing options...
Revolver Posted December 9, 2009 Report Share Posted December 9, 2009 Disc brakes don't seem to work when bled with water. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted December 9, 2009 Report Share Posted December 9, 2009 you can. but it might not work Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 9, 2009 Author Report Share Posted December 9, 2009 you can. but it might not workit wont wrek the seals though will it? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted December 9, 2009 Report Share Posted December 9, 2009 It may do. And if you use the brake too much the water may heat up too much/boil and not work Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted December 9, 2009 Report Share Posted December 9, 2009 If you bleed a disk with water and drag it down a hill, it will most likely not work, and you will die. Quote Link to comment Share on other sites More sharing options...
Ashley Sayers Posted December 9, 2009 Report Share Posted December 9, 2009 i dont think you should bleed disk with water mate Quote Link to comment Share on other sites More sharing options...
davey1991 Posted December 9, 2009 Report Share Posted December 9, 2009 Maguras are fine to use with water as the pads don't heat up and there away from the pistons.Disks you should never ever use water, it will more than likely ruin your sealsand as you use the brake the ceramic of the pads will heat up, the water will boil and the brake will loose all power.The DOT fluid designed for disk brakes is far more resistant to heat. Quote Link to comment Share on other sites More sharing options...
TrialsMan Dan Posted December 9, 2009 Report Share Posted December 9, 2009 Why would you want to bleed any brake with water? Even if it is a HS brake. The disadvantages outweigh the advantages and you'll just make it less reliable. Quote Link to comment Share on other sites More sharing options...
JT! Posted December 9, 2009 Report Share Posted December 9, 2009 Why would you want to bleed any brake with water? Even if it is a HS brake. The disadvantages outweigh the advantages and you'll just make it less reliable.I get what you're saying. But people do it because it's just easier, less messy and gives the leaver a lighter feel. Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted December 9, 2009 Report Share Posted December 9, 2009 Maguras are fine to use with water as the pads don't heat up and there away from the pistons.Disks you should never ever use water, it will more than likely ruin your sealsand as you use the brake the ceramic of the pads will heat up, the water will boil and the brake will loose all power.The DOT fluid designed for disk brakes is far more resistant to heat.DOT fluid is only for hope brakes. Magura discs use mineral oil.I bled the disc on my mod with water years ago and it was fine. At one point I even used a HS 33 lever and it still worked fine the lever just felt stiff.I can't remember exactly how I did it but I'm pretty sure I used a syringe and bled from the caliper up to the lever.Its not the best idea to use water with a disc brake but it does work. I didn't notice the water getting hot, expanding or boiling when I did it so I think you'll be alright for trials.Don't forget that you'll have no warranty if you do it though. Quote Link to comment Share on other sites More sharing options...
zoo 06 Posted December 9, 2009 Author Report Share Posted December 9, 2009 DOT fluid is only for hope brakes. Magura discs use mineral oil.I bled the disc on my mod with water years ago and it was fine. At one point I even used a HS 33 lever and it still worked fine the lever just felt stiff.I can't remember exactly how I did it but I'm pretty sure I used a syringe and bled from the caliper up to the lever.Its not the best idea to use water with a disc brake but it does work. I didn't notice the water getting hot, expanding or boiling when I did it so I think you'll be alright for trials.Don't forget that you'll have no warranty if you do it though.thanks for the infomation lads, im goin for it lol. Quote Link to comment Share on other sites More sharing options...
Dale-Hill Posted December 9, 2009 Report Share Posted December 9, 2009 thanks for the infomation lads, im goin for it lol.Youra f**king tard then!DO NOT USE WATER IN DISCS. Did you not read that it rapes the seals and it will boi land NOT wrok? Quote Link to comment Share on other sites More sharing options...
5murf Posted December 10, 2009 Report Share Posted December 10, 2009 (edited) Youra f**king tard then!DO NOT USE WATER IN DISCS. Did you not read that it rapes the seals and it will boi land NOT wrok? Ive done it with my Magura Louise and it works fine I will probably change it to sunflower oil soon though. Edited December 10, 2009 by 5murf Quote Link to comment Share on other sites More sharing options...
shamus Posted December 10, 2009 Report Share Posted December 10, 2009 topic in a few weeks- water bled brake and loss of power- help!inside is a picture of a smashed up ownerbrake fluids are used for a reason, if a manufacturer could reliably use water (a far cheaper option) don't you think they would? Quote Link to comment Share on other sites More sharing options...
JT! Posted December 10, 2009 Report Share Posted December 10, 2009 brake fluids are used for a reason, if a manufacturer could reliably use water (a far cheaper option) don't you think they would? Quote Link to comment Share on other sites More sharing options...
Danny Metcalfe Posted December 10, 2009 Report Share Posted December 10, 2009 and you will die.You Emo. Quote Link to comment Share on other sites More sharing options...
FINDUS Posted December 11, 2009 Report Share Posted December 11, 2009 If you bleed a disk with water and drag it down a hill, it will most likely not work, and you will die.I think this post confirms the answer is no!! YOU WILL DIE Quote Link to comment Share on other sites More sharing options...
