Hope Iso Brake Adaptor
trialsmax04
bought a 200mm hope adaptor for my mate. Went to fit it on his bike and the mount holes on the fork and the mount on the brake where so far out its stupid. Do they require modifying or is this just a duff one?
Max
Try and get a pic up to see what's going on. What hope adaptor is it, HBIS20?
As Craig said we need either more info or a pic. If the forks and the brake are IS fitting the adapter should jst bolt straight up to both with the only room for error being which caliper/adapter/rotor combination you're running. Does the caliper bolt up fine but is in the wrong place for the rotor or does it not go on the forks at all?
It's an echo urban fork / echo pure with a standard hope adaptor. The top of the mount on the fork is hitting the adaptor, once the fork or adaptor ahs had a small amount of material removed it'll fit fine. Then you'll have the problem of 200mm adaptor with 203 rotor :)
Edited by Alex Dark
