Lei ke si Posted December 3, 2009 Report Share Posted December 3, 2009 (edited) i have a hope mini front but how much i press it have no braking power..it can stop on a normal ride but if i hop to front it have no power ..sorry for bad english Edited December 3, 2009 by Lei ke si Quote Link to comment Share on other sites More sharing options...
FINDUS Posted December 3, 2009 Report Share Posted December 3, 2009 i have a hope mini front but how much i press it have no braking power..it can stop on a normal ride but if i hop to front it have no power ..sorry for bad englishCan be a number of things...new padsdirty rotorand i think mainly a bleed!and if your feeling clever maybe an upgrade to a braided hose i found mine improved once changed Quote Link to comment Share on other sites More sharing options...
Vortexor Posted December 3, 2009 Report Share Posted December 3, 2009 Ey Up,I got the same problem and this is possibly caused by:- Old Pads or a substance on the pads- Old/Dirty Rotor- Bleed Your BrakeI have the same kind of problem and asked about this problembefore and this was the feedback i got, and i still can't be botheredto sort it i will soon though. Hopefully this infomation helped you mate. Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted December 3, 2009 Author Report Share Posted December 3, 2009 but my bolt rounded i can not bleed how to take out the bolt..thanks alot Quote Link to comment Share on other sites More sharing options...
David 200909 Posted December 3, 2009 Report Share Posted December 3, 2009 Try setting it up again. Make sure the pads draw into the middle of the caliper when the lever is pulled, then. Put the caliper onto the disc in the right place and pull the lever to clamp the caliper against the disc and cable tie the lever to your bars to lock the caliper in place. Then, spend a bit of time getting the exact right spacers to fit between the caliper and the brake mount on the forks/frame. Fit them and tightened the bolts up. It took me a few attempts to get it mine right, it needed different sized spacers for the top and bottom bolts, to get it to sit in the right place after it was tightened up. But I'm glad I took my time to got it right, I pretty much just have to lean my finger againt the lever and it locks the front wheel SOLID! HOPE RULES!Trial to Live---Live to Trial Quote Link to comment Share on other sites More sharing options...
josh barker Posted December 3, 2009 Report Share Posted December 3, 2009 Your pads may be contaminated?? Quote Link to comment Share on other sites More sharing options...
Lei ke si Posted December 4, 2009 Author Report Share Posted December 4, 2009 how come Quote Link to comment Share on other sites More sharing options...
sam singlehurst Posted December 8, 2009 Report Share Posted December 8, 2009 i would say it needs a fresh bleed and your rotor is probs contaminated Quote Link to comment Share on other sites More sharing options...
