How Do I Bleed My Hydraulics With Water?
Ashley Sayers
ive tryed that (the bucket way ) it wade no sense?
Tisn't that hard...undo both bleed screws. Immerse in water. Cover the lever bleed hole, depress lever fully. Now release lever, and stop covering bleed hole.
Repeat up to 40 times, whilst periodically tapping the slave, MC and line to release any air bubbles
Refit bleed bolts and you're good to go (Y)
That means you're doing it wrong.
Put brake in water
Undo bleed screws
Cover lever hole with finger fully, leave slave hole uncovered
Press lever all the way in quickly.
With the lever depressed, quickly cover the slave hole with your finger fully, and leave the lever hole uncovered
Release the lever quickly
Repeat many times.
Basicly. open both the bleed screws and put the brake in the bath and fill the bath with COLD water. Then get one of your mates to help you out and put your finger over the bleed hole on the lever and leave the one on the slave cylinder and give the lever a pull. Next get you mate to put his finger on the bleed hole on the slave cylinder and then you let go of the hole on the lever and then release the lever and then repeat these steps untill all bubbles stop coming out of the cylinder. Finally reinstall the bleed screws underwater to reduce the chance of getting air into the system to a minimum
