Improving My Hope Mono
bikeperson45
My Hope Mono disc brake on the front is getting very slowly worse. I want it so that when I do up to fronts the wheel is locked and doesn't start rolling. Will new pads work, they're not completly worn but their not amazingly new either. And do i have to bleed the brake when I change them? Is there any other ways of improving it's performance?
Thanks
An interesting point to note.
If you want your mono to bite like a maggie (but you will loose modulation) put some aluminium washers under the bolt heads, it'll throw you over the bars if your not careful!
Hmmm interesting that, my front one has washers underneath and has loads more bite than my rear with out. Might give it a shot.
Yo Rob, as I said last weekend take the rotor off and stick it in the oven for 30minutes. This should burn off any residue etc, give it a good rinse in warm water after though.
As for the pads I just scrub them with a little fairy liquid and then rinse, dry with paper towels and reatatch.
You won't need to bleed after doing this although if you're comfortable doing a bleed you could do.
Remember do NOT pull the lever without the rotor as the pistons will get pushed all the way out and could damage them. Also remember that when you put these parts back on your bike you will need to throw water on / have brake half on just to bed them back in.
Hope I helped and I better see you tomorrow xD
  • 1 month later...
give them a thorough scub and rinse with petrol, then wipe and make sure they are dry (the same for the rotor too)
aside from using pretty expensive brake cleaner, this will take all dirt, and more importantly all oils/greases off
The bolts that hold the caliper to the forks/ adaptor :S
(Y)
What was said about the washers btw, I have washers under the bolts (on the outside of the mount so all it sits between the bolt head and the frame.) Not sure how that helps but its what i've got :P
(Y)
Aluminium washers, don't know why it works but does. Loose all modulation.
