*Koxx hydroxx 2 Jack * Posted November 27, 2009 Report Share Posted November 27, 2009 Hi all , ive just tryed fitting a rear bb7 on my ice frame , and the rotor appears to be hitting on the frame , what can i do to solve this ? the parts that may be of help are : try all wheel onza ice frame and an avid bb7 185 disk brakemany thanks , jack Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted November 27, 2009 Report Share Posted November 27, 2009 I had this problem on my Onza blade.I didn't really know what I could do though, so went back to magura Quote Link to comment Share on other sites More sharing options...
davey1991 Posted November 27, 2009 Report Share Posted November 27, 2009 its a mod 160mm rotor would solve it, and thats about it, unless you'll run a longer chain? Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted November 27, 2009 Author Report Share Posted November 27, 2009 its a mod 160mm rotor would solve it, and thats about it, unless you'll run a longer chain?a 160 would not fix it im afraid , the bit its rubbing on is only 20mm or so away from the caliper Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 27, 2009 Report Share Posted November 27, 2009 Pictures or i cant really help...id say probably space the hub away from the frame Quote Link to comment Share on other sites More sharing options...
Borat Posted November 27, 2009 Report Share Posted November 27, 2009 Man up and ride it, your from essex... Nahh, get some pics up and us super nerds will help. Quote Link to comment Share on other sites More sharing options...
Duncy H Posted November 27, 2009 Report Share Posted November 27, 2009 Just a thought, are you running snail cams? Because even though it has built in tensioners the spacing could be 116mm and some hubs are 110 without snail cams Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted November 27, 2009 Author Report Share Posted November 27, 2009 Just a thought, are you running snail cams? Because even though it has built in tensioners the spacing could be 116mm and some hubs are 110 without snail cams nope , not running snail cams ill try and get some pics up soon though Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted November 28, 2009 Author Report Share Posted November 28, 2009 I had this problem on my Onza blade.I didn't really know what I could do though, so went back to magurawhat wheel were you trying to run with it mate ? Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted November 28, 2009 Report Share Posted November 28, 2009 what wheel were you trying to run with it mate ?Echo Disc hub. My mate had the same set up, and he just spaced the hub away from the frame, then put washers on the bolts.. Quote Link to comment Share on other sites More sharing options...
RossMcd Posted November 28, 2009 Report Share Posted November 28, 2009 have you tried re-alligning your wheel? that will solve it.. if your wheel is off center slightly it will rub. Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 28, 2009 Report Share Posted November 28, 2009 have you tried re-alligning your wheel? that will solve it.. if your wheel is off center slightly it will rub.The wheel being out of dish isn't going to stop the disc hitting the frame.By the sounds of it its most likely the hub spacing is for a frame running snail cams on the inside of the dropouts, like has been said and as suck the rotor now sits too close to the frame. Do as some lad did and get some washers on your hub bolts and space it out a bit Quote Link to comment Share on other sites More sharing options...
