George.E Posted November 25, 2009 Report Share Posted November 25, 2009 (edited) Basically my drive system is pathetic My frame is an Echo Lite 07Echo TR hub with Echo TR snail camsKHE collapse 1/8 chainA 12t sprocket on the rearThe old Tesnsile 18t freewheel on the frontRight - First off, with my frame am I ment to run my snail cams on the inside off the frame or the outside ?I have been running the cams on the outside lol.Secondly - Iv taken out as much links from the chain as it will let me to fit on the sprokets, I tension the snail cams as far as they will go and I get hardly any tension on the chain.There is enough room to take one link out but as you know that isn't possible ha.Can anyone tell me what to do or any ideas ?Thanks guys I would love some help George Edited November 25, 2009 by Echo lite 94 Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted November 25, 2009 Report Share Posted November 25, 2009 Run the cams on the inside, but that wont make a difference to your chain tension, get some bigger snail cams, or put washers on the snail cam bolts. Quote Link to comment Share on other sites More sharing options...
George.E Posted November 25, 2009 Author Report Share Posted November 25, 2009 Run the cams on the inside, but that wont make a difference to your chain tension, get some bigger snail cams, or put washers on the snail cam bolts.Thanks for that, an ok I will try that and I thought the TR cams were some of the biggest ?What will washers do when there on the snail cam bolts ? Quote Link to comment Share on other sites More sharing options...
ISO2 Posted November 25, 2009 Report Share Posted November 25, 2009 Ive a set oif Echo TR and there too small, i need bigger as well. Tarty told me they are the biggest! Quote Link to comment Share on other sites More sharing options...
N.Wood Posted November 25, 2009 Report Share Posted November 25, 2009 Put larger, thick washers in between your bolt and frame. Or use a larger headed bolt. Quote Link to comment Share on other sites More sharing options...
Mat Smith!! Posted November 25, 2009 Report Share Posted November 25, 2009 Thanks for that, an ok I will try that and I thought the TR cams were some of the biggest ?What will washers do when there on the snail cam bolts ?if you put say 5mm washers inside of the bolt and frame, it will act as a bigger bolt head, for the snail cam to push up against, this giving u 5mm more chain tension, doesnt sound alot, but it is lol. Quote Link to comment Share on other sites More sharing options...
ISO2 Posted November 25, 2009 Report Share Posted November 25, 2009 if you put say 5mm washers inside of the bolt and frame, it will act as a bigger bolt head, for the snail cam to push up against, this giving u 5mm more chain tension, doesnt sound alot, but it is lol.Someone sticky that!!! Just tried it and at last i have my bike properly set up! Never though of it my self! A steel washer is best really Quote Link to comment Share on other sites More sharing options...
George.E Posted November 26, 2009 Author Report Share Posted November 26, 2009 if you put say 5mm washers inside of the bolt and frame, it will act as a bigger bolt head, for the snail cam to push up against, this giving u 5mm more chain tension, doesnt sound alot, but it is lol.Cheers mate that sounds like that will fix my problem because Im not even running washers behind my bolts.Thanks a lot, I will try it later on. Quote Link to comment Share on other sites More sharing options...
matty121 Posted November 26, 2009 Report Share Posted November 26, 2009 I have this problem aswell with my mod czar frame and hub, when i put a washer to make the snail cam move further away the tyre rubbed on the brake pads because the wheel was so far back so im unsure of what to do now as the brake mounts dont go any further back! any sugestions..? sorry dont mean to steal your post, but i feel its related and could help you Quote Link to comment Share on other sites More sharing options...
George.E Posted November 26, 2009 Author Report Share Posted November 26, 2009 Ok iv been out and had a go, using the snail cams on the inside of the frame i can get enought tension on the chain.But the snail cams catch on the chain so its no good, and i can't use washers because there isn't enought axel left to go in the drop outs.Any help would be lovely . Quote Link to comment Share on other sites More sharing options...
