Prevent Punchers
Hi i have been prone to getting punched so i thort of a way to make it harder to get one
What i did:
I got an old innertube and cut the valve out and cut all the way round the old tube and
placed it over my new tube and put the tyre back on the wheel
and i had myself a double thickness innertube on budjet
and i have not had a puncher since
try it out (Y)
tell me what you think
What i did:
try it out (Y)
  Soon to be Rowan Johns said:
Sounds like a great idea,
I might try it, im constanty getting pinched on mis-judged steps and things.
How heavy is it though? does it effect your acceleration? does it effect handling?
cheers
Aymon
Well it'd be like having two innertubes, so around 200g heavier
of course it affects acceleration, how much depends on the weight though.
Doubt it, probably affects how the bike handles in the air to some minute degree though.
You're best off getting a thicker DH tube, or a thicker dual ply tyre if you;re forever getting " punctures"
A 2ND tube is a good idea this was what i used years ago, but now i use car seat belts! they are very light weight easy to fit and i have not had a puncture with them not even snake bites as you fit them right into the rim :D
you can get them from any car scrap yard or like me from an abandoned car! (Y)
