Brake Bleeding With Water
Jiten
My friend said that if I bleed the brake with water, in the winter it will freeze and break my HS33's
Is this true?
It will freeze when winter rolls around if your bikes outdoors....however ive had them freeze on me, even while riding and it's done them no damage whatsoever :)
IF you're that bothered, whack some anti-freeze in there (Y)
As the water freezes, it expands slightly and pushes your pads towards your rim. That's about it, really. It just means you can't ride, so putting a bit of anti-freeze in with your water means you can ride with a water bleed all year round.
