Hs33 Bleeding
kevtim
How do you bleed maguras as one of my current brakes is a little crap and i've never needed to do it before? Any step by step info anywhere with tools, tips for a good brake set up? I just wondered what the differences between bleeding maguras with oil and water are also? Is one better than the other? All help much appreciated thanks!
Kev
The wiki is good for bleeding, but are there any tips for setting up/aligning the calipers using 4 bolt mounts? I always find this a real pain in the ass, and almost impossible to get the pad alignment perfect.
take 1 credit card, ram it between the wheel and your pad, do the brake up, take card out and do on the other side
