MrLongboard Posted November 23, 2009 Report Share Posted November 23, 2009 building up some new cranks soon and came across these ...http://www.sjscycles.co.uk/product-Talon-P...32-Inch-301.htmis this the correct type of front cog i need to run with trialtech sport forged 160mm arms and a tensile bashring?? im going to be running it with a 15t rear cog on my hope pro2.its the same 1.37 x 24 tpi thred as the cranks ....If it is id be delighted as ive just reliased they are made by the company my brother works for!!! cheers Quote Link to comment Share on other sites More sharing options...
scotty007 Posted November 24, 2009 Report Share Posted November 24, 2009 building up some new cranks soon and came across these ...http://www.sjscycles.co.uk/product-Talon-P...32-Inch-301.htmis this the correct type of front cog i need to run with trialtech sport forged 160mm arms and a tensile bashring?? im going to be running it with a 15t rear cog on my hope pro2.its the same 1.37 x 24 tpi thred as the cranks ....If it is id be delighted as ive just reliased they are made by the company my brother works for!!! cheerslooks to me that you can run this sprocket on those crank arms and with the hope pro 2 hub you may need a locking ring to fit with your bashgaurd and sprocket, making sure that everything aligns properly for sweet running run a 18:15 ratio Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 24, 2009 Report Share Posted November 24, 2009 Yeh that looks fine, bear in mind that that cog is made from aluminium and so will wear away far faster than a Cromo steel version. Thread size etc it looks fine No lockring needed, maybe a spacer for the cranks if you run no bashring though Quote Link to comment Share on other sites More sharing options...
