The Hitcher Posted November 23, 2009 Report Share Posted November 23, 2009 Hello, Can someone tell me what them really high riser bars are called and were to get them please. I think ali c used them and i have seen a fair few others using them. Cheers. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted November 23, 2009 Report Share Posted November 23, 2009 Few people have been running BlkMrkt 3" risers or Gusset Open Prison bars. If you need big rise then there's a fair few options available though often only in 25.4mm clamp variants. Come to the kitchen, have some of my sweet sausagey goodness and let's hook you up a spec instead of coursework stuff... Quote Link to comment Share on other sites More sharing options...
The Hitcher Posted November 23, 2009 Author Report Share Posted November 23, 2009 Few people have been running BlkMrkt 3" risers or Gusset Open Prison bars. If you need big rise then there's a fair few options available though often only in 25.4mm clamp variants. Come to the kitchen, have some of my sweet sausagey goodness and let's hook you up a spec instead of coursework stuff...its alex mate found these http://www.ison-distribution.com/ison/engl...hp?part=HBGUOPK Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted November 23, 2009 Report Share Posted November 23, 2009 My point still stands Quote Link to comment Share on other sites More sharing options...
John Shrewsbury Posted November 23, 2009 Report Share Posted November 23, 2009 its alex mate found these http://www.ison-distribution.com/ison/engl...hp?part=HBGUOPKyeh i got a set of them, but didnt get on with the sweep on them. Just bn stickin with azonic single walls or double wals atm. Dave- inspired bicycles are gonna be doing sum bars soon, and ullbe able to run a trialtech stem to give it a higher rise. Quote Link to comment Share on other sites More sharing options...
The Hitcher Posted November 23, 2009 Author Report Share Posted November 23, 2009 yeh i got a set of them, but didnt get on with the sweep on them. Just bn stickin with azonic single walls or double wals atm. Dave- inspired bicycles are gonna be doing sum bars soon, and ullbe able to run a trialtech stem to give it a higher rise.i see, interesting stuff. I may wait for them then, it is a bit of a pain if i did get the gusset ones because i would have to change my stem. I run an echo stem with monty ti bar risers at the moment and i dont feel quite right with them. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted November 23, 2009 Report Share Posted November 23, 2009 I was running a similar setup on mine at first as it's all I had, but since then changed to a 90*15 stem, few spacers, and a set of 2.5" Azonics and it's spot on. The Azonics have a much more comfortable shape so you'll probably get on better with them, especially coming from the Montys Quote Link to comment Share on other sites More sharing options...
notknown Posted November 23, 2009 Report Share Posted November 23, 2009 control tech scandium. tartybikes. love mine. Quote Link to comment Share on other sites More sharing options...
The Hitcher Posted November 23, 2009 Author Report Share Posted November 23, 2009 I was running a similar setup on mine at first as it's all I had, but since then changed to a 90*15 stem, few spacers, and a set of 2.5" Azonics and it's spot on. The Azonics have a much more comfortable shape so you'll probably get on better with them, especially coming from the Montys Yours didn`t feel quite right with me, felt it needed to be higher. Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 23, 2009 Report Share Posted November 23, 2009 (edited) Was going to say controltech's or answer pro tapers. Edited November 23, 2009 by craigjames Quote Link to comment Share on other sites More sharing options...
