josh barker Posted November 23, 2009 Report Share Posted November 23, 2009 hi all,i am wanting help with my heatsink cnc backings, in one of them the o ring that keeps them secured to the slave cylinder seems to be a bit stiff compaed to the other and when i set my brake perfectly to the rim after a ride there will be a gap at the top of the pad to the slave cylinder but the bottom part of the pad will be normal. can you replace the rubber o rings as i think this will solve the problem or am i better off buying some new ones.help much appreciated. Quote Link to comment Share on other sites More sharing options...
josh barker Posted November 24, 2009 Author Report Share Posted November 24, 2009 someone must know?? Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 24, 2009 Report Share Posted November 24, 2009 Yup, you can replace the o-rings, although i very much doubt that's your problem. I don;t reckon the o-ring resisting compression would be enough to overcome the power of a magura? Quote Link to comment Share on other sites More sharing options...
josh barker Posted November 24, 2009 Author Report Share Posted November 24, 2009 Yup, you can replace the o-rings, although i very much doubt that's your problem. I don;t reckon the o-ring resisting compression would be enough to overcome the power of a magura? i think the orings nacord it doesnt have the same fitting feel as the other Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 24, 2009 Report Share Posted November 24, 2009 i think the orings nacord it doesnt have the same fitting feel as the otherIf it's knackered, then replace it. Go to an o-ring supplier, somewhere like Mill Autos or similar Quote Link to comment Share on other sites More sharing options...
josh barker Posted November 25, 2009 Author Report Share Posted November 25, 2009 If it's knackered, then replace it. Go to an o-ring supplier, somewhere like Mill Autos or similar cheers matey for advice Quote Link to comment Share on other sites More sharing options...
tonyblythtrials123 Posted November 25, 2009 Report Share Posted November 25, 2009 i had this problem, and i gave it to my dad and he just cleaned it out or summin and it worked fine after that Quote Link to comment Share on other sites More sharing options...
josh barker Posted November 25, 2009 Author Report Share Posted November 25, 2009 i had this problem, and i gave it to my dad and he just cleaned it out or summin and it worked fine after thatwill keep that in mind cheers Quote Link to comment Share on other sites More sharing options...
