Folding Bead Tyres For Trials
ginger allen echo
That's what I use. If you're running tyre pressure low enough to pull the tyre off then a steel bead will pull off pretty much as easily. Raising the tyre pressure or using a wider rim or a tyre with a heavier wall will all contribute to keeping the tyre seated on side loads.
