*Koxx hydroxx 2 Jack * Posted November 22, 2009 Report Share Posted November 22, 2009 hi guys , the bash plate on my onza ice frame is bent too fook/ pretty much snapped after the 1st 10 min ride , there is no way i can think of to put the rubber in has anyone else had this problem ? even better , overcame it ?cheers jack Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted November 22, 2009 Report Share Posted November 22, 2009 use something softer than the rubber, Ie few kitchen sponges?Or, Just take the bash plate off, with bike upside down, put the rubber on the frame, then the bash, put the top bolt in, put all your weight on the bash and you should be able to get the bottom two in, if that makes sense? shouldn't be too hard to figure out.xxxx Quote Link to comment Share on other sites More sharing options...
hdmackay Posted November 22, 2009 Report Share Posted November 22, 2009 I had the same problem mate. The rubber wouldn't fit in. So I cut up an old inner tube and rolled it up. Works nicely. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 22, 2009 Report Share Posted November 22, 2009 Why not jsut get a bash ring? Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted November 22, 2009 Report Share Posted November 22, 2009 Because Jack is the biggest basher EVER! Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 22, 2009 Report Share Posted November 22, 2009 It doesn't really make a difference.. if your a basher or not Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted November 22, 2009 Report Share Posted November 22, 2009 It doesn't really make a difference.. if your a basher or notThe man is right...Lighter too Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted November 22, 2009 Report Share Posted November 22, 2009 cut the rubber with a knife ? Quote Link to comment Share on other sites More sharing options...
*Koxx hydroxx 2 Jack * Posted November 22, 2009 Author Report Share Posted November 22, 2009 Why not jsut get a bash ring?my bb is not long enough cut the rubber with a knife ?because i need a bigger rubber not smaller , cheers anyways though Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 22, 2009 Report Share Posted November 22, 2009 The man is right...Thankyou Mr Bazzocavich.okay then stay with a bash plate. But if you have the money get a new bottom bracket. Quote Link to comment Share on other sites More sharing options...
