onzaboy09 Posted November 22, 2009 Report Share Posted November 22, 2009 (edited) On tarty it says that the bolt size is m6 would this fit on my onza t-comp 2009? Edited November 22, 2009 by onzaboy09 Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 On tarty it says that the bolt size is m6 would this fit on my onza t-comp 2009?i mean onza t-comp 08 Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 anyone know Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 22, 2009 Report Share Posted November 22, 2009 (edited) Try doing this.I presume you have the bolt holes for snail cams already, so:Take a bolt out of your bike. You want a stem bolt or the top cap bolt, 'cause these are both M6.Put it in the hole.If it goes in, it fits, if it doesn't, it doesn't.Then come back on here and worship me for my ingenuity.I might add that not all stem bolts are M6, lol. The top cap bolt is though. Edited November 22, 2009 by Revolver Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 22, 2009 Report Share Posted November 22, 2009 (edited) On tarty it says that the bolt size is m6 would this fit on my onza t-comp 2009?i mean onza t-comp 08anyone knowYou don't need to bump your topic twice within half an hour Edited November 22, 2009 by ginger allen echo Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 22, 2009 Report Share Posted November 22, 2009 YEAH.ROCK that emoticon. Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 If I wanted to bump I would of said 'bump' Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 22, 2009 Report Share Posted November 22, 2009 If I wanted to bump I would of said 'bump'Did you do it?I mean, you can either go and do that and know instantly, or sit here on your arse waiting for hours before someone with the right answer comes along. Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 it is an m5 bolt that fits into it so could i use an m5 bolt for the monty snail cam? Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted November 22, 2009 Report Share Posted November 22, 2009 I don't think you should get snail cams. I think you should upgrade to decent chain tugs.Does your bike take take chain tugs?If so, get some chain tugs Quote Link to comment Share on other sites More sharing options...
Borat Posted November 22, 2009 Report Share Posted November 22, 2009 I don't think you should get snail cams. I think you should upgrade to decent chain tugs.Does your bike take take chain tugs?If so, get some chain tugsChain tugs are a pile of wank. Fact. Quote Link to comment Share on other sites More sharing options...
JT! Posted November 22, 2009 Report Share Posted November 22, 2009 The monty snail cams bolts are M6, onzas take M5's.You can use the monty snail cams with an M5 bolts, i know because this is what i'm currently doing. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted November 22, 2009 Report Share Posted November 22, 2009 Chain tugs are a pile of wank. Fact.Not the beefy gusset ones. Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 22, 2009 Report Share Posted November 22, 2009 it is an m5 bolt that fits into it so could i use an m5 bolt for the monty snail cam?If you knew this, you should'nt've asked...Jsut use the current bolt. Simple! Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 how are the snail cams used to tension the chain? and what length bolt would i need? Quote Link to comment Share on other sites More sharing options...
Ullapool Trials Rider Posted November 22, 2009 Report Share Posted November 22, 2009 Not the beefy gusset ones.I meant the gusset ones. They are amazing Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 22, 2009 Report Share Posted November 22, 2009 You obviously have some form of tensioner already? Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 22, 2009 Author Report Share Posted November 22, 2009 At the moment I have onza chain tugs but they are forever braking so I am thinking of trying out snail cams. Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted November 22, 2009 Report Share Posted November 22, 2009 if your getting snail cams dont get the monty ones as mine slipped all the time because the metal just eat away get some echo ones much better Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 23, 2009 Author Report Share Posted November 23, 2009 how long did you have them before they started to slip? Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted November 23, 2009 Report Share Posted November 23, 2009 about a month then the pin just went through the cam so then got some echo cams and they have been good as gold Quote Link to comment Share on other sites More sharing options...
onzaboy09 Posted November 23, 2009 Author Report Share Posted November 23, 2009 were they the red ones Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted November 23, 2009 Report Share Posted November 23, 2009 they were black but the metal is the same insnt it ? Quote Link to comment Share on other sites More sharing options...
