Echo Tr Lever
Jack Morton
16 members have voted
  1. 1. If I was to bleed this brake with mineral oil would it leak ?, as Deng levers at known for leaking if I am correct
    • Would be fine
      12
    • Would leak
      1
    • All deng levers leak, Arnt worth the hastle stay with magura
      2
    • Would devlop a leak early on in its life
      1
  2. 2. Is the piston in it the same size as the ones found it magura HS33's ?
    • Yes
      10
    • No
      6
  3. 3. Are they worth the money ?
    • Yes
      11
    • No
      5
  4. 4. Or should i just stick with magura
    • Stick with magura
      7
    • Try them out
      9
I cracked my Magura so I need a new lever and when looking on tartybikes fell in love which these. My questions are
IF SOMEONE HAS HAD EXPERIENCES WITH THESE LEVERS COULD YOU PLEASE TELL ME WHAT YOUR VIEWS UPON THEM ARE AND IF YOUR'S DEVELOPED A LEAK
Many thanks Jack
Edited by Jack Morton
Get the TR.
TPA system is better, look a lot neater, and if you run all magura fitting, hose and pistons, you won't have a problem with leaks, as long as it's bled with mineral oil.
They're soooo much comfier than normal magura levers, and even when bled with oil, they're quick and responsive.
I've been using the TR for a couple of months now, and I must say, it's a very good brake. The lever feels great, and looks pretty too.
Only problem I've had, is the adjusting screw unscrewing itself when you press the lever. This has become quite annoying, but I guess it can be fixed with some kind of Loctite.
the pistons are a differant size , he plastic backed pads fi fine but cnc backings do not fit unfortunately :( simple file job sorts em out but they never work the same
What? lol
hes on about the lever.
EDIT: and how do cnc backings never work the same if you file them? :Slol
Edited by Mat Smith!!
