Mikey-uk Posted November 21, 2009 Report Share Posted November 21, 2009 Heya, Onza Citrus on a dead grind are no good in the wet and only somtimes good in the dry (depends if there's an invisible layer of dust or somthing else on the rim) so i'm looking for some decent pads.I was told that the LGM's were amazing but acording to Tarty they're better for ground rims wheras the CRM's are advertised for smooth, light grind or dead grind.What do you guys think about the pads? Or are there any other pads decent on a dead grind?NOT going to grind my rim so don't even sugest it Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 21, 2009 Report Share Posted November 21, 2009 Grind you ri- Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Pads that are good for a smooth rim:Phat padsHeatsink Yellows and SnowiesTnn Lgm'sHeatsink CoustsIf you can get hold of some, this could be quite hard. But the famous Heatsink Reds.Or as reveolver has just said, grind your rim for the best performance. Edited November 21, 2009 by ginger allen echo Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 21, 2009 Report Share Posted November 21, 2009 Heya, Onza Citrus on a dead grind are no good in the wet- NO PAD WILL BE ON A DEAD GRINDCRM's are advertised for smooth- WHERE CAN YOU GET CRMs FROM?NOT going to grind my rim so don't even sugest it - WHY NOT? Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 (edited) Thanks allen, i'm not grinding the rim but neither am I running it on a smooth rim. I need a brake that will be beast on a dead/worn grind, why do you mention the LGM's but not the CRM's which are specified to be used on a worn grind?Ben, just had a look and seen that they're listen as discontinued. No idea why they're still on tarty though :/ Edited November 21, 2009 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 I have been on three different bikes that have had the CRM's on a smooth and grind. They were all pretty rubbish.Iv'e got the LGM's on a smooth and they are insane!Heatsink Yellows are supposed to be a very good pad to use on a dead grind. Or you could sand your sidewalls down with wet and dry sandpaper.How did you get the link to the CRM's? tarty ahve taken them off the website. Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 (edited) I have been on three different bikes that have had the CRM's on a smooth and grind. They were all pretty rubbish.Iv'e got the LGM's on a smooth and they are insane!Heatsink Yellows are supposed to be a very good pad to use on a dead grind. Or you could sand your sidewalls down with wet and dry sandpaper.I'll have a look into the Heatsinks, even though these pads are for chrismas i'd rather have them within the next 3-4 weeks and have heard that although steve is a good salesman and has good quality products he is also very slow to reply / ship said products.I probs will sand my sidewalls down sooner or later, I would grind but I don't want to have to maintain the grind and eventually replace the rim unless I have to.Click on the green refills and then follow a link to them I'll email adam about this error. Edited November 21, 2009 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted November 21, 2009 Report Share Posted November 21, 2009 eventually replace the rim unless I have to.Eventually, the rim would of probably broke before you put too many grinds on it! Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 I'll have a look into the Heatsinks, even though these pads are for chrismas i'd rather have them within the next 3-4 weeks and have heard that although steve is a good salesman and has good quality products he is also very slow to reply / ship said products.I probs will sand my sidewalls down sooner or later, I would grind but I don't want to have to maintain the grind and eventually replace the rim unless I have to.Click on the green refills and then follow a link to them I'll email adam about this error.Cheers haha. yer haha I orderd some Cousts from him two and a bit weeks before christmas. You would have thought he would have sent them in that time but he obviously didn't.So I got them two weeks after christmas.. That wasnt helpful when i really needed some new pads haha. Quote Link to comment Share on other sites More sharing options...
Borat Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Mikey, like I said on mesennn. Get the Tnn Lgms, my grind is as dead as Ghandi; yet they are amazing in the wet and dry. No slip at all, as I will prove to you tmrw. Edited November 21, 2009 by Borat Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 I thought you were running smooth rims Chinners? :( Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 Mikey, like I said on mesennn. Get the Tnn Lgms, my grind is as dead as Ghandi; yet they are amazing in the wet and dry. No slip at all, as I will prove to you tmrw.xD tomorrow should be safe Convincing my dad now to get the Lgm's and the try-all crank/bb bundle for (early)christmas presents.Allen thought you was running smooth and I thought you didn't want to run a disk? Why would you need forks? Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 (edited) Allen thought you was running smooth and I thought you didn't want to run a disk? Why would you need forks? 'Cos that isn't confusing Don't you mean Mr Borat? Edited November 21, 2009 by ginger allen echo Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 21, 2009 Report Share Posted November 21, 2009 'Cos that isn't confusing Lmao. Not not all Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 *Why would he need disk forks.Better? Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 You still don't make any sense :| Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 21, 2009 Report Share Posted November 21, 2009 What have disk forks got to do with anything lol Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 *Sigh* I was talking to Jack about his sig, told me he hates disks and went back to maggy even if it meant using standard onza forks..... Clearer now? xD Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 21, 2009 Report Share Posted November 21, 2009 What *pause* the *pause* hell *long pause* are you on about? Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 Jack posted in this thread, Allen said about he was running smooths and i said about him running a maggy and having DISK FORKS WANTED in his sig despite not wanting to run disks Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted November 21, 2009 Report Share Posted November 21, 2009 Who's Jack? WHAT THE f**k IS TRIALS!? Quote Link to comment Share on other sites More sharing options...
hdmackay Posted November 21, 2009 Report Share Posted November 21, 2009 Who's Jack? WHAT THE f**k IS TRIALS!?Why did you feel the need to do that? Just joking babe. Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 Who's Jack? WHAT THE f**k IS TRIALS!?F**king rofl! haha i love you BJH!!! Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted November 21, 2009 Author Report Share Posted November 21, 2009 Jack is Borat and trials...... Quote Link to comment Share on other sites More sharing options...
ginger allen echo Posted November 21, 2009 Report Share Posted November 21, 2009 No shit Einstein, he was being sarcastic... Quote Link to comment Share on other sites More sharing options...
