Front Magura
Jan Tore
FAQ Guidelines
This is for people to post INFORMATION only. If you need the answer to a question, please ask in trials chat. If you have useful information you think will be handy for other members, please to post it! Thanks.
But anyway.. Magura HS33 (and v-brakes) have way more bite than discs. Personally i would recommend a front v-brake but that's just preference.
FAQ Guidelines
Sorry about posting here then..
Anyway, how is the lever feel with a wire break? I might just try a vee. How's the bite/hold on a vee?
I think the bite and hold with v-brakes is pretty much the same as maguras.
Anyway here is some good stuff about vee's ;)
Vee's have soo many advantages.
They feel quicker
They are easier to set-up
Pads don't get rounded edges because there is no play in vee pads.
Lighter
Parts are more widely available. Cables etc.
More powerful than Magura's and discs
You don't have to deflate your tyre to take your wheel off
Levers like the Sd7 lever have a TPA (barrell adjuster) aswell as a power adjustmant so you can get the perfect feel out of your brake
The list goes on to be honest.
I wouldn't reccommend getting the Ultimates to be honest. They are very very expensive and the SD7's are great and cheap.
  • 4 weeks later...
Personally, i think that if you practice street or extreme natural is best V-brake or maguras.
If you practice "standard" natural maybe is best front disk.
I had the same question arround my mind a month ago when my magura louise lever blade broke....
Then I though to change to HS33, avid bb7 disk or Hope.
My Louise was under waranty and my blade was changed for free, but now i'm quite sure to continue with disk, my level is not extreme and i like a lot natural.
