Fixies
Best/safe(st) way would be to buy a bolt on sprocket, but that obviously costs money. Will be worth it though when you don't eat shit on a hard downstroke.
EDIT: IF your hub has a disk mount. If not, there aren't any brilliant ways to do it.
Edited by Ben John-Hynes
welder
bolt (as said)
replace springs with something rigid so pawls cant retract
file your hub flange into the shape of a sprocket and use that
steal an actual hub
ebay
put your fingers in the drive mechanism, turn the freewheel to mangle your fingers, put a bit of bone in there to jam it up, rebuild it
glue
take the sprockets off a cassette and just slot them onto a cheap fixed hub
replace casette bearings with cashew nuts
lots of ways, be creative
There's nothing wrong with it, I just have an old hub laying around, and wondered what it would be like to fixie it and give that a go.
Thanks for all the suggestions, even the one's that weren't so useful were quite amusing
I'll probs give the metal-filler a try,
I'll keep you updated if i lose any teeth
Aymon
