Simple Cage V.s Double Cage
315r
Hello.
I'm just thinking to transform my double cage to simple because the simple reason that a lot of people with more or less level mount simple cage.
The question is WHY?
More grippy? Less weigh?
And the best way to transform are aluminum separators?
Thank you.
single cage = less weight, thats about it really
Ok, that's all? Just for weight?
I'm not sure that changing double for simple with aluminium separators the difference will be very different. :ermm:
And for shoes? Maybe the simple cage is more aggressive?
Just the difference I've seen between my double cage and a freind's single, theres a little more grip because there's more pressure on the shoe.
Less surface area, more pressure. The second cage supports your foot a bit more and makes it a little flatter on the pedal, making your foot a bit more likely to slip off the pedal.
When you have a single, your foot will sag a little into the center of the pedal and give you a little bit for your foot to push against and stop your foot from slipping forward or back. You may find yourself chewing up your shoes a bit more with one cage though...
Just my understanding of it...
Edited by Dr.scratchensniff
Seems about right....Single are definitely a LOT more grippy though
Grippier, less weight, and then you've also got the additional bonus of the bolt catching more thread in the pedal body. With the double cage on, it seems like the bolts come loose quite easily 'cos there's not much thread from the bolt getting inside the body - with the inner cage taken out, you get another 1-2mm of thread in there, which should do the trick (Y)
Aha! Thank you!
EDIT:
Therefore in order:
Pros:
- More grippy.
- Less Weigh.
- Makes pedals stronger.
Contras:
- Aggressive with shoes
- Less comfortable.
Didn't really notice any kind of difference in terms of comfort to be honest, I wouldn't worry about that. I guess it'll wear your shoes a bit more, but I'd rather have shoes that wear out slightly faster than getting more shin-hits from slippery pedals ;)
Nowadays i don't have problems of grip with my double cage.
Therefore you recommend me to make my pedals single cage?
Remember that since you recommended me a Trialtech bar I believe you very strongly. ;)
Contras:
- Less comfortable.
Don't forget that they'll tear the shit out of your shins a lot worse than double cages if you slip and get your shin into them.
You are a lot less likely to slip but if you do, and your leg is in the unfortunate path of the pedal, you're getting torn.
I'm making mine singles now though because I'm not really doing anything hardcore enough to slip properly and I've accepted that shin cutting happens, by riding a bike with V8's for a while...
Definitely, I left my pedals double cage.......
Thank you!!!!
Just remembered to check this thread! Out of single and double, I'd definitely recommend single. It just seems to work a lot better, and the pros definitely outweigh the cons. If you switch to single and don't like it, it's pretty easy to change back - may as well give it a go (Y)
Also the try-all superlights cages are far superior to the normal double caged ones(different grade metal i think), i havnt bent the cage in any way yet, also because the pedal body its self is so thin it allows the cages to sit further in to the bottom of your shoe increasing the grip as compared with traditional double cage bodys were due to the size of the pedal body your foot would rest on it meaning less force on the cage its self(i think:P), this increases the wear rate of your shoes as stated but it is deffinately worth it also i dont think comfort comes to much into it i feel more comfortable having more grip :P
