Guantanamo Posted November 16, 2009 Report Share Posted November 16, 2009 Right, i had no luck getting the mangled starnut (if you've read my previous topic you'll know what i'm taking about) out of my forks and can't trim the steerertube. I have to ride 30mm of stem stackers (spacers) does this matter too much? riding an Onza Zoot with trialtech stem (120mm x 17*) monty bars and viz forks.Thanks Quote Link to comment Share on other sites More sharing options...
duncan_echo26 Posted November 16, 2009 Report Share Posted November 16, 2009 30mm isn't too much. If its too high then you could put a spacer or two on top of the stem. Quote Link to comment Share on other sites More sharing options...
King C Posted November 16, 2009 Report Share Posted November 16, 2009 30mm in terms of stem stackers is quite a lot. That will change the effective stem angle, and to some extent the length, a considerable amount. Unless you put them on top that is. Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 16, 2009 Author Report Share Posted November 16, 2009 30mm in terms of stem stackers is quite a lot. That will change the effective stem angle, and to some extent the length, a considerable amount. Unless you put them on top that is.Bearing in mind it's 24". Was thinking it's a fait bit. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted November 16, 2009 Report Share Posted November 16, 2009 Compensate by running a shorter, lower stem if needs be and throw some of the spacers on top. Done Quote Link to comment Share on other sites More sharing options...
Guantanamo Posted November 16, 2009 Author Report Share Posted November 16, 2009 Any way of saying how many spacers i need? Looks too much to me Quote Link to comment Share on other sites More sharing options...
Liamlikesonza Posted November 16, 2009 Report Share Posted November 16, 2009 Take advantage of it and make a cool pattern like gold and black that would make it look good and put them on top aswell. Jobs a gud en!Liam Quote Link to comment Share on other sites More sharing options...
