Ffw Advantages
terry26rims
The lightest FFW setup isnt any lighter than the lightest king setup (there isnt much in it though), what it does do is move the weight of the ratchet forwards off the back axle to give a more neutral centre of gravity; a ffw is also cheaper to replace than a king.
However if you currently have a freehub then you will need a new rear hub (plus associated wheel rebuild), new set of screw on cranks, bashguard, screw on sprocket and the freewheel.
If you're already setup with a rear freewheel, the cost vs advantages of changing to FFW is rubbish. There are pros and cons of both front an rear freewheel but to just justify going from FFW when you've already got a RFW setup it's just stupid.
Can always sell your cranks and rear hub on though which would offset the price by a reasonable amount, I'd have thought? Depends how you play your cards I guess.
Which rear hub are you using at the mo?
Starting with a screw on rear hub you can still use that, but you'll need new cranks and a 15T screw on sprocket (To give the most common ratio for a stock bike, if you ride a Mod you'll need a 12T screw on sprocket). Make sure the BB you have is long enough to have room for a FFW as well - certain combinations are known to have issues.
I'm not too sure about the strength of the Dicta freewheels, but putting it on the front will load it slightly more heavily as the gear ratio multiplies up the torque seen by the freewheel, so if the freewheel you have already needs a lot of attention to keep it running it will need more on the front.
