crispyboy Posted November 15, 2009 Report Share Posted November 15, 2009 Hello everyone i was wondering if it is possible to buy a rotor even smaller than the Try-All ones which are 155mm ?If so anyone used one ? Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 15, 2009 Report Share Posted November 15, 2009 think you can buy 140mm rotors, think its either formula or magura that use them.... Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted November 15, 2009 Report Share Posted November 15, 2009 Most companies do 140mm rear for XC racers, including Hope. You'd have to use a 160mm front caliper and it would only work if the disc mount was standard, not +20+30 ect Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 15, 2009 Report Share Posted November 15, 2009 Why would you want to? Avid do a 140mm i think..... Quote Link to comment Share on other sites More sharing options...
crispyboy Posted November 15, 2009 Author Report Share Posted November 15, 2009 Why would you want to? Avid do a 140mm i think.....Well on the Rockman i have,the disc mount is really low into the frame so i have to run a adaptor to raise it up to standard but i think with a 140mm it might work as normal with no adaptor ?Any one recon it would work ? Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 15, 2009 Report Share Posted November 15, 2009 Kinda depends on which caliper you're using I guess. Ads built up his Rockman on Friday and literally just bolted his caliper directly to the frame, and it's pretty much spot on. Literally the easiest disc installation I've ever seen. Not even any spacers. Amazing. In any case though, don't forget that if you do put a 140mm rotor on you'll be losing power compared to the disc you've got on now. Quote Link to comment Share on other sites More sharing options...
crispyboy Posted November 15, 2009 Author Report Share Posted November 15, 2009 Is Adam running the number 6 Hope ?What disc rotor ? Quote Link to comment Share on other sites More sharing options...
Duncy H Posted November 15, 2009 Report Share Posted November 15, 2009 I use a number 3 caliper on mine. Mine also went on really easy with no spacers I believe you have the try-all brakes? That is why you have to run the caliper.I think you are better off with the rotors around the 160 size Quote Link to comment Share on other sites More sharing options...
grant wildman Posted November 15, 2009 Report Share Posted November 15, 2009 Most companies do 140mm rear for XC racers, including Hope. You'd have to use a 160mm front caliper and it would only work if the disc mount was standard, not +20+30 ectspot on , usualy a hope numbe 5 caliper is a 160 front and 140 rear brake .not much advantages other than clearence with a smaller rear disc , unless you weigh 7stone........?x Quote Link to comment Share on other sites More sharing options...
