FINDUS Posted November 13, 2009 Report Share Posted November 13, 2009 hi guys, i have a chris king single speed hub i want to convert the bolt through axel size from the 12mm down to 10mm is there any way i can do this?? reason is i have a leeson 24" with the 360 drop outs and the bolts are made to fit 10mm, my hope pro 2 trials 48 engagement fits as its a 10mm. but as i have a king i wanna use this!! any idea`s please let me know thanks chris Quote Link to comment Share on other sites More sharing options...
josh barker Posted November 13, 2009 Report Share Posted November 13, 2009 buy an axle off tarty http://www.tartybikes.co.uk/product.php?pr...;category_id=22 Quote Link to comment Share on other sites More sharing options...
Skoze Posted November 13, 2009 Report Share Posted November 13, 2009 Hey man, i ran my HD King (one with the fun bolts) in my Leeson 609, all it needs is the dropout drilling out to be flush withe the hole in the bottom of the insert, i used a big ass pillar drill thingy at my dad's place. Easy job, took all of 10 minutes and is fine. Did it on my 660 too, actually. Quote Link to comment Share on other sites More sharing options...
FINDUS Posted November 13, 2009 Author Report Share Posted November 13, 2009 buy an axle off tarty http://www.tartybikes.co.uk/product.php?pr...;category_id=22I looked at that,I already have the uprated axel! It came with the fun bolts as standard.I think what i need is the thred size like the fun bolt but hollow and to have a tread inside to make it 10mm..my only other option is to try and get a long rod that is 12mm thick and 145mm lenght and put it right through the hub and use my tap and dye to bring just the ends down to 10mm. eg 135mm threaded to 12mm and 5mm either end cut to 10mm so it will slot into my frame. theN good old nut and bolt finish.Does that make any sense?? the link below will show pics of the 360 dropout.. http://www.leesonbikes.co.uk/609.htmlHey man, i ran my HD King (one with the fun bolts) in my Leeson 609, all it needs is the dropout drilling out to be flush withe the hole in the bottom of the insert, i used a big ass pillar drill thingy at my dad's place. Easy job, took all of 10 minutes and is fine. Did it on my 660 too, actually.Cool do you have any pictures to help me understand a little more?? Quote Link to comment Share on other sites More sharing options...
Skoze Posted November 13, 2009 Report Share Posted November 13, 2009 (edited) Yeah sure dude, i'll get you some tomorrow when there's some decent light Don't have the hub or bolts anymore though, swapped them for a bike yesterday - i made some bolts up too to work with the inserts (effectively using the inserts as washers) but i'm sure it'll work exactly the same with standard bolts, they were exactly the same dimensions. Edited November 13, 2009 by Skoze Quote Link to comment Share on other sites More sharing options...
FINDUS Posted November 13, 2009 Author Report Share Posted November 13, 2009 Yeah sure dude, i'll get you some tomorrow when there's some decent light Don't have the hub or bolts anymore though, swapped them for a bike yesterday - i made some bolts up too to work with the inserts (effectively using the inserts as washers) but i'm sure it'll work exactly the same with standard bolts, they were exactly the same dimensions.Brill thankyou very much. It will be a great help..What could you ever swap a leeson for that is anywhere near as good?? Quote Link to comment Share on other sites More sharing options...
Skoze Posted November 14, 2009 Report Share Posted November 14, 2009 (edited) The bmx that's currently sat right next to me Dunno man, trials scene's just gone sour recently, isn't what it used to be, nor something i want to be a part of... Was a deal i couldn't pass up. Still got the frame kit though, so it's gonna get built up again for next year's roadtrip As for the pics, awfully sorry but i forgot :$ Tomorrow though!!! Edited November 14, 2009 by Skoze Quote Link to comment Share on other sites More sharing options...
